THANKS OLD07....TRY WD 40 GOT GOOD RESULT. WHEN I GOT TO WORK
TRYED VALVOLINE \\; PENETRATING OIL..WENT FOR A RIDE..EVERYTHING IS PERFECT...
 \\; \\; \\; \\; \\; \\;&n bsp\\; \\; \\; \\; \\; \\;&nbs p\\; \\; \\; \\; \\; \\; \ \; \\; \\; \\; \\; A BIG THANK YOU FROM THE NORTH
Fatbob. Nice to hear that fixed the problem. Now quit using the space bar so much. The forum is hard enough to read without you adding so many backslashes every time you double space.
ORIGINAL: FATBOB.
TRYED VALVOLINE \\;\\\\\\; PENETRATING OIL..WENT FOR A RIDE..EVERYTHING IS PERFECT.. \\;A BIG THANK YOU FROM THE NORTH
OK now that you found out what the problem is you have to fix it,WD40 is not the fix.Take it apart and clean all that crap oiut of there and put some "neve seize" on it for lubrication or it WILL happen again.Dave...
ORIGINAL: FATBOB.
TRYED VALVOLINE \\\\\\;\\\\\\\\\\\\\\; PENETRATING OIL..WENT FOR A RIDE..EVERYTHING IS PERFECT.. \\\\\\;A BIG THANK YOU FROM THE NORTH
