Stage 1 debate continues
Old Jul 31, 2008 | 02:11 PM
2007fxdc's Avatar
2007fxdc
Default Stage 1 debate continues
I was reading through my new issue of AIM and once again found a statement saying the stock ECM should be able to handle a stage 1 a/c and slipons with no remapping or aftermarket devices.&nbsp\\; What gives?&nbsp\\; In my experience, that just wasn't the case.
Old Jul 31, 2008 | 02:14 PM
2007fxdc's Avatar
2007fxdc
Default RE: Stage 1 debate continues
To clarify, a guy wrote in asking if he needed anything for this setup and the response was no, the ECM should handle such small modifications.&nbsp\\; Even the so-called experts contradict themselves on this subject.
Old Jul 31, 2008 | 02:52 PM
dougm1950's Avatar
dougm1950
Could I ask what AIM is?
Old Jul 31, 2008 | 02:57 PM
Redbeard's Avatar
Redbeard
American Iron Magazine
Old Jul 31, 2008 | 02:59 PM
Bluesssman's Avatar
Bluesssman
Listen to your engine, is it detonating? Pull your plugs and read them. However, I think you will find modifying your fuel management will improve your performance. Personally, I really like the PCIII.
Old Jul 31, 2008 | 03:01 PM
dyna07custom's Avatar
dyna07custom
HD says with a/c you need a remap
Old Jul 31, 2008 | 10:05 PM
steel_tiger1's Avatar
steel_tiger1
Hmm. Have been thinking about getting A/C and fuel pak since I installed V&amp\\;H Straightshot HS slipons. Maybe I don't need either. Bike seems to be really running hot but it is in the mid 90's. I have no oil temp gauge.
Old Jul 31, 2008 | 10:09 PM
BluBob's Avatar
BluBob
FuelPak will not help your heat issue.
Old Jul 31, 2008 | 10:21 PM
steel_tiger1
I had read on this forum that more air &amp\\; fuel in the mix will help some as it runs hotter if it is too lean.
Old Aug 1, 2008 | 07:50 AM
2007fxdc's Avatar
2007fxdc
ORIGINAL: BluBob
&nbsp\\;
Is that so?&nbsp\\; Sure helped mine.
