Riser bushing- HOW TO
Old Apr 6, 2012 | 03:14 PM
Steel Steed's Avatar
Steel Steed
Good info! Did you go with the the polymer bushings or rubber? Just wondering how the vibrations are before and after.
Old Apr 6, 2012 | 03:53 PM
JRK5892's Avatar
JRK5892
i always go poly... always
Old Jun 24, 2012 | 10:13 AM
Guest
Guest
Posts: n/a
Wink Gotta go poly
Yeah the stock bushings are rubber (to dampen the vibes) but if you go anything over stock you can generate too much leverage and you risers can flex. Factory specs factory specs factory specs on the bolts. Or you Will get excessive vibration. Trust me. Too tight=too much vibes
Old Jun 24, 2012 | 12:15 PM
hellbob37's Avatar
hellbob37
Instead of pulling on the bottom with pliers and Risking any damage from the pliers slamming down when it pops how about a flathead and a rubber hammer to tap it out from the top...; ).
Old Jun 27, 2012 | 04:10 PM
Livnoutdoorsxd9's Avatar
Livnoutdoorsxd9
Ill be doing this shortly, thanks for taking the guesswork out of the method!
Otter
May 27, 2017 10:11 AM
Voony
Aug 22, 2011 06:33 AM
yandeltx
Sep 29, 2010 07:11 AM
freddyttt
Jan 14, 2010 06:04 PM
rap87
Jul 27, 2006 08:51 AM
