Question handlebar change
Old Aug 12, 2008 | 04:41 PM
ifishwalleye's Avatar
ifishwalleye
Default Question handlebar change
I have 2008 FXDC and getting ready to change the Oem bars to mini apes from street bob.
my question today is some guys said they have enough of the electrical wire when they pulled
out from frame, do you have to release a tie wrap or something somewhere?, I pulled on mine and nothing much came out of front of frame.
I got to do this myself, dealer says 6 hours of labor and they say they need to splice all wires.
thanks
Old Aug 12, 2008 | 05:13 PM
rounder's Avatar
rounder
zip tie that releases the wires under the seat attatched to frame right behind the tank mount...at least on 05 models....
did you get to the connectors and discover nothing much or have you not reached those. If so above may apply.
Old Aug 12, 2008 | 05:34 PM
ifishwalleye
I did get to any connectors, I just pulled a little and did seem to want to pull out any.
I was afraid If I pulled too much I would pull a wire out of a connector or something.
Old Aug 12, 2008 | 05:35 PM
Slipstrm's Avatar
Slipstrm
My 07 Had enough wiring to get the slack I needed.
Old Aug 12, 2008 | 05:40 PM
ifishwalleye
slipstrm, did you need to release some wire ties to be able to pull wire out?
Old Aug 12, 2008 | 05:43 PM
Slipstrm's Avatar
Slipstrm
Nope, I just had to pull the Rubber grommets out of the holes on the sides of the frame where the wires come out, I also took off the piece under the frame to allow me to get my hands up in there a little bit.
Old Aug 12, 2008 | 05:46 PM
ifishwalleye
Okay I'll try that, thanks for your help.
Ron
Old Aug 13, 2008 | 02:15 AM
carltex's Avatar
carltex
I did this same thing on my FXD. On the under side of the neck of your frame there is a plastic cover, take it off for access to the wiring. The wiring is probably just jammed in there and giving you problems so just move stuff around a little to free the wire up and it should come on out. I had a hard time with mine and actually pulled the wire loose from the connector thus leading to finding the plastic cover.
Old Aug 13, 2008 | 08:03 AM
NoShoes84's Avatar
NoShoes84
Just a side note...Your bike should have the key switch up on the frame under the rubber grommet like my 06 Low Rider. The wires for the switch (3 red with prongs) are plugged in to the frame way up inside the frame. If you giggle around too much without being careful these will come out. It really isn't much fun trying to get them back in unless of course you have really really tiny hands. By the way...my low rider didn't have any wire ties anywhere but I really doubt what your dealer was telling you especially if you are running the wires on the outside of the stock street bob bars. I had 3 hours invested in the entire install and I ran the wires through the bars. God I hate the stealerships.
big kal
Jan 12, 2013 04:03 PM
McGinnes_john
Dec 22, 2012 02:30 PM
Dannell53
Jan 24, 2011 12:33 PM
Redbob 07
Jun 27, 2010 08:32 PM
whited44
Oct 20, 2008 06:00 PM
