lowering front end...
Old Aug 13, 2008 | 12:37 PM
jsbridgew's Avatar
jsbridgew
wow, i didn't realize you could drop them in the trees for some reason... just never occured to me...i mean, it's obvious you can... but just didn't 'see' it for some reason...HA!
Old Aug 13, 2008 | 01:18 PM
Wonderbob's Avatar
Wonderbob
+1 I'm going to try it myself...
Old Aug 13, 2008 | 01:27 PM
ode sku's Avatar
ode sku
drop it in the trees if that solves your prob then lower with kit
Old Aug 13, 2008 | 01:31 PM
jsbridgew's Avatar
jsbridgew
exactly 'ode sku'....drop in trees, test ride, look at it, then put the street bob tubes on when i break it down for powdercoat
Old Aug 13, 2008 | 03:30 PM
bosken's Avatar
bosken
I cant drop mine more than half inch....the handlebar is in the way . Need higher risers!
Old Aug 13, 2008 | 03:41 PM
JRK5892's Avatar
JRK5892
i would not go lower than an 1 in in the front.. your dyna has frame rails under the bike that will hit on bumps and driveway... if you go any lower
Old Aug 22, 2008 | 01:46 PM
jsbridgew's Avatar
jsbridgew
You're right JRK, i saw that.... went only 3/4 inches.... looks better and performs better... weird what just a little adjustment like that can do.
Old Aug 22, 2008 | 02:42 PM
CRF's Avatar
CRF
at least you HAVE risers....:-(
Old Aug 22, 2008 | 03:41 PM
SPECIAL ED's Avatar
SPECIAL ED
Bosken, lowering 1/2" is enough to make a noticeable difference in handling and stability with a lowered rear end.Also it shouldn't be too tough to make a spacer to extend the risers 1".
ajk511
Feb 8, 2015 07:45 AM
jmerchant.1
Jul 29, 2014 06:06 AM
vecter
Aug 1, 2010 09:13 PM
lhcstreetbob
Dec 13, 2008 12:47 PM
