finished up all the damage from the accident
Old Aug 17, 2008 | 01:59 PM
freebyrd's Avatar
freebyrd
Thumbs up finished up all the damage from the accident
went out today and changed my black fin derby cover for the old original chrome that i still had lying around, while i was in there i deadjusted the clutch lever and oiled it and did the adjustment on the clutch pack someone should mention that if you do this adjustment yourself make sure the bikes out of neutral or when you put your 11/16ths wrench on and turn it to loosen up the clutchpack the whole thing will just turn,lol
anyway got it done oiled up the cable and left about a 16th of an inch play or about the width of a dime on the lever,
took it out for a spin and shes fluid tight and shifts beautifully
i kept the black fin derby cover and pancake gasket and sure enough there is a crack running from the top bolt hole and runs about an inch and a half straight down the cover, i think it can be welded and go back on fine and the fin cover itself isn't all that scratched up there are a few blemishes that can be ground down with a dremil tool i think,touch up with some black paint and put it back on in the spring
anyways thanks for all the help as i mentioned before in another thread there are good people here
freebyrd
sjoefl01
Jul 12, 2017 09:04 AM
Bagged64
Touring Parts
Jul 7, 2017 07:37 PM
15Fe883
Aug 25, 2015 10:45 AM
foglies
May 26, 2014 11:01 AM
OldFenderGuy
Aug 22, 2006 12:55 PM
