driving lites
Old Aug 23, 2008 | 11:07 PM
98glider's Avatar
98glider
Default driving lites
Did anybody add on driving lites on their superglide. i have a 98 and was wondering if I can install with out hurting the alternater. and where would be a good place to mount any sugg thanks
Old Aug 24, 2008 | 09:49 AM
Bugger's Avatar
Bugger
Default Driving lights
Not sure if this helps but the electrical diagnostics manual talks about an alternator load test (run engine at 3000 RPM, increase the load with the load tester as required to obtain a constant 13 VDC). The maximun current draw should be in the range of 35-50 AMPS. The manual futher states that the current output of the alternator should exceed the current draw by 3.5 AMPS. Now if you had an ampmeter you could clip it arround the negative battery cable, turn on the ignition switch (don't start it though!), turn on all continuously running lights and accessories, switch to high beams and see how much total current draw you have. My guess is that you're much less than the 35-50 AMPS. In fact the main buse fuse is a 40 AMP fuse. The alternator should handle anything you throw at it. However, the subcircuits are limited by 15 AMP fuses. So, what kind of driving lights are you thinking of adding? HD has some that mount to the engine guard. They are 55 watt each. 55 watts X 2/ 12volts = a little over 9 AMPS. Lets hope the circuit that you add these driving lights to does not allready have more than 5 or 6 AMPS running through the 15 AMP fuse. To see what I did, read this thread: https://www.hdforums.com/forum/showt...highlight=dual
DianneB
Dec 21, 2014 04:24 PM
RidemyEVO
EVO
30
Apr 22, 2014 03:00 PM
rk10
Jun 24, 2012 08:59 PM
jimmie d wad
Electrical/Lighting/Alarm
Jun 30, 2009 09:27 PM
mark10
Apr 19, 2008 06:26 PM
