EFI to Carb conversion?
Old Aug 12, 2009 | 06:21 PM
  #81
Mascman's Avatar
Mascman
Originally Posted by the blob
ditch the pc3 and get a tts/masterune then tune your bike yourself. trust me you will
be happy!!! no more dynos just use the v-tune software that comes with it and do your
own so called dynos!!!
i got mine from fuelmoto it was around 350.00.
Is there a base map to start with? Does it measure the A/F ratio?
Old Aug 12, 2009 | 07:28 PM
  #82
man4mopar's Avatar
man4mopar
Yes to a base map and sort of to the AFR ratio. All said even if you just did the base map with your Air cleaner and Exhaust swaps only you will be just fine.
I suggest reading info on the TTS.
Old Oct 1, 2009 | 08:35 AM
  #83
Voony's Avatar
Voony
Hey all!
I realize this is an old topic but I'd like to ask a couple of questions:
1) When you mean "dowload" upgrades for EFI bikes, you really mean like with a computer? How does EFI exactly works? I have no idea...my only bike I had so far (before I can get my HD) was an old carb dirt bike...it was not HD ok but in 30+ years it never leaked once. Always worked smoothly.
2) Isn't it to be more reliable that HD started to put EFI on their bikes? I didn't know it had something to do with EPA. I thought the new engines and stock pipes were made to match EPA regulations?
3) a HD with a carb will always sound better anyway correct? :-)
4) You blow up your warrenty if you switch for a carb?
Old Oct 1, 2009 | 08:46 AM
  #84
bigdaddy33's Avatar
bigdaddy33
1. Yes
2. Don't know if EFI is more reliable than a carb. Probably better if riding through a range of altitudes. I'm sure the EPA requirements sped up the shift to EFI.
3. In my opinion, yes.
4. Yep.
Old Oct 1, 2009 | 08:56 AM
  #85
ackman1968's Avatar
ackman1968
Originally Posted by Voony
Hey all!
EFI was for the EPA, not relability. Ask anyone running a carb and they'll tell you they are very reliable when tuned properly for the conditions. My old Road King ran like a champ day in day out.
Old Oct 1, 2009 | 09:25 AM
  #86
DGDyna's Avatar
DGDyna
Hey all!
You have much to learn Grasshopper. Listen and you will become wise.
Old Oct 1, 2009 | 09:57 AM
  #87
Voony's Avatar
Voony
THis is why I ask questions to old farts
Old Oct 1, 2009 | 10:18 AM
  #88
SC-Longhair's Avatar
SC-Longhair
EFI works the same way on a bike as it does a car. A computer (ECM) decides when and how much gas to inject into the cylinder. Although it does have it's limitations. A download will increase the max. an ecm can do.
Most people will buy add-ons like the dynojet powercommands III (version three) or the newer V (five). You are then able to download your own maps to it using a computer, the powercommander software and a long usb cable.
Old Oct 1, 2009 | 11:14 AM
  #89
Voony's Avatar
Voony
That sounds like something very weird to do on a Harley Davidson. I'm just having problems to link HD and dowloading a software, using a usb cable and a laptop to upgrade something related to the engine.
Old Oct 1, 2009 | 11:17 AM
  #90
Herr Monk's Avatar
Herr Monk
Hey all!
A computer controls the fuel/air. A "map" determines at what throttle % and engine speed, how much fuel is delivered, to achieve the desired A/F ratio. A download or "flash" is a prepackaged map (like the stock map your bike comes with) for specific modifications.
Good EFI is better than carb for 99.99% of us. Old EFI systems were clunky and didn't work that well, the new is great. EFI allows you to "safely" run the bike leaner (read cleaner), at around a 14.7:1 A/F ratio. Carb is less precise, so you wouldn't want to "tune" it that lean, as you could end up going super lean. EFI allows you to set it up so you only go that lean cruising under light load.
If by better you mean a more traditional sound... than probably... part of it too though, is that the Twin Cams (carbed or not) have to be run at a higher idle level than the Evos, but with a Carbed Twin Can you can just twist a *** to slow it down, where EFI is "stuck" where it's programed (although not hard to reprogrammed). So it's really the engine more than the fuel delivery.
[/QUOTE]
Like anything, if you change it, it's no longer covered, and if it's the change that caused the problem, you're no longer covered.
