Where's Nuetral?
Old Mar 28, 2006 | 12:27 AM
mojo's Avatar
mojo
Default RE: Where's Nuetral?
Thanks KB!
Old Mar 28, 2006 | 01:04 AM
jackyl's Avatar
jackyl
treat it like a women ,slow and easy,u will get the hang of it
Old Mar 28, 2006 | 01:33 AM
mojo's Avatar
mojo
The few short rides i have been on I did treat it like a lady, but maybe I just need to do as you say and get used to it. Is this something new with the trannys cause my other HD's never had the problem. I treated them more like an ex-wife verse a lady and they poped in to neutral first try all the time. I will call MoCo like KB mentioned in the morn and see what I find out and go from there. Like others have posted it is only neutral, all other gears work fine, but trying to get it in neutral is one of those deals where you have to look around to make sure someone isn't watching, laughing, usually I am in my garage so the only one watching me is my dog, but i bet he gets a chuckle out of it too Thanks again guys! mojo
Old Mar 28, 2006 | 03:42 AM
route2null0's Avatar
route2null0
ORIGINAL: jackyl
Oh, you just opened a can... hahah!
j/k
Old Mar 28, 2006 | 11:30 PM
mojo's Avatar
mojo
After checking out the link from LOWTOW and the suggestions from KB, I found the recall and called MoCo and my bike does need the recall. I went out and verified on bike the issue I thought I was having verse the issue in the recall. I thought I was unable to find neutral when it seems I was probably in neutral if I would of released the clutch to see but since the neutral light didn't come on i assumed, yep assumed, My bad! so I wil get it in for the replacement shift drum and new neutral light switch and see if that cures the problem. Thanks to all for your help as I have been overseas and wasn't aware of this recall. mojo
Old Mar 29, 2006 | 01:02 AM
rfhermo's Avatar
rfhermo
I had trouble finding N, before I had the recall work done. After the recall work, finding the big N is much, much easier.
Old Mar 29, 2006 | 01:28 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: mojo
Great...now after its fixed try the 75w90 Mobil1 gear lube or the Redline Shockproof Heavy and you will really like your 6 speed.
Old Mar 30, 2006 | 05:01 PM
eleutheros's Avatar
eleutheros
I've had trouble finding neutral. I've learned it's much easier to do before stopping. The kill switch is a bad idea; it's for emergency.
normannewguy
May 8, 2019 03:55 PM
GMRO
May 4, 2015 03:52 PM
June Bug
Oct 30, 2010 11:03 PM
sctusa
Jan 13, 2009 11:23 AM
Bat
Jun 1, 2008 07:36 AM
