Rear tire...
Old Sep 28, 2008 | 07:51 AM
YellowHawk's Avatar
YellowHawk
Default Rear tire...
I am going to have to replace my rear tire real soon. I just noticed yesterday that the tread right in the center is wearing quite thin. If I buy a tire and remove the rear wheel, can I take it anywhere that changes tires and have the new one put on or does it need to be taken to a motorcycle shop somewhere? This is the first rear tire I've had to change. Thanks.
Old Sep 28, 2008 | 08:08 AM
Rodney's Avatar
Rodney
I would suggest taking it to a motorcycle shop or a shop who offers to do motor bike tires. Our local automotive tire store refuses to work on motor cycle tires..
I do my own tire changing on the garage floor using an old piece of carpet for padding, some tire irons and a lot of sweat!
Old Sep 28, 2008 | 08:40 AM
YellowHawk's Avatar
YellowHawk
Okay, thanks for the info.
Old Sep 28, 2008 | 10:19 AM
HELDVR's Avatar
HELDVR
Hey YellowHawk, bring it to a motorcycle dealer. Hats off to Rodney but the best I can do is dirtbike and atv tires! And if you do try to do it yourself, do it when the tire is warm! Cold tires are a beayatch!!
You might also think about going to the 180 Screamin' Eagle (from the stock 160) It's about 3/4" wider. Got mine off ebay and brought it to the dealer to change. Also can try www.surdyke.com for HD parts approximately 20% list. When you take in to consideration NO TAXES, the saving add up! Shipping is typically 5% of the total?
Good luck!
Old Sep 28, 2008 | 10:42 AM
YellowHawk's Avatar
YellowHawk
I won't try it myself. My luck I'd destroy the rim. I just wasn't sure if any tire service center could do the work.
Old Sep 28, 2008 | 11:12 PM
08fxdf43202's Avatar
08fxdf43202
I took my wheel and my new tire to the dealer, they changed the tire and balanced the wheel for $45 (while I waited).
Old Sep 29, 2008 | 12:01 AM
rockon's Avatar
rockon
If you do go with the 180 SE kit, Chicago HD has it online for $20 less than Surdyke.
http://chicagoharley.com/shop/advanc...8-06&x=12&y=15
canicta
Feb 14, 2016 09:46 AM
kzoo
Mar 22, 2012 09:26 AM
trackadaptor
Nov 8, 2009 08:26 PM
devils haircut
Aug 11, 2008 10:13 PM
dirico1266
Feb 5, 2008 04:45 AM
