need help changing 82 fxe to fl
Old Sep 29, 2008 | 11:46 AM
JeffroBodeen's Avatar
JeffroBodeen
1st Gear
Default need help changing 82 fxe to fl
I was wondering if anybody out there could steer me in the right direction in getting a hydraglide front end on my superglide.
heres the problems, i want to keep stock dual discs, and i want to put those 3 degree offset fork cups in the neck. stock fl lower legs only have one caliper mount and when i stretch it out,and going from 19" rim to 16" ill want longer slider tubes. So im prepared to do the change in pieces. Is there any flst front end that will work, or maybe somebody knows if fl slider covers will fit on fxwg forks, or just have a better idea period.
Old Sep 29, 2008 | 11:59 AM
new_mentor70's Avatar
new_mentor70
I ran a setup like this on my 82 SG, It can be done.
Im not sure whos parts I had because I bought the bike in a box.
but It had Custom chrome or V-twin lower forks and I ran the OE front dual discs.
the Triple tree must have been of a soft-tail or somthing because nothing matched up in the neck and I had to get the cups cut down and change a couple of other things, but the bike look like a fatboy when I was done!
hopfully some else can give you alittle more acuate info, becuase I build this bike over 10 years ago and the details are foggy!
but for sure it CAN be done!
Old Sep 29, 2008 | 01:42 PM
JeffroBodeen
1st Gear
i knew i couldnt be the only person to ever have this vision i hope i can find some one to help with the interchange issues
Old Sep 29, 2008 | 02:33 PM
wbogley's Avatar
wbogley
I have a 1981 FXE. Did you check the J&P Cycles catalog for front ends? I know they have the wide glide forks for the shovels, but I am not sure about a FL front end.
Old Sep 29, 2008 | 04:09 PM
JeffroBodeen
1st Gear
yeah, pretty much every aftermarket co. has the parts to build a front end that will fit my bike, but id have to sacrifice and get a whole new brake system i guess if i have to
Spider1220
Jan 2, 2018 03:38 PM
Crazy
Mar 21, 2015 09:42 PM
LooseMoose
Mar 23, 2011 01:12 PM
JeffroBodeen
Shovelhead
Sep 29, 2008 02:23 PM
JeffroBodeen
Sep 29, 2008 11:12 AM
