ordered apes need help with cable length
Old Oct 11, 2008 | 08:14 PM
jordanball33's Avatar
jordanball33
Default ordered apes need help with cable length
i just ordered a set of 17 inch ape hangers for my 07 street bob, im having trouble withe cable length, i cant seem to get the right information, and relay that to an online dealer, i know i need like +10 throttle idle, but they want the total length of the cables, i know some places can go off of the +10 but at jirehcycles.com they just want the full length, and the throttle and idle cables are 11 dollars a peice, so its hard to turn down that deal, so any help anyone could be would be appreciated. and if anyone wants to know about the bars i ordered, they are 17 inch narrow body, so i think they will go good with the dyna, but they were like 69, good price, nice looking bars, PM me if anyone wants the info
Old Oct 11, 2008 | 08:30 PM
BluBob's Avatar
BluBob
Go to the Harley parts site and select enter throttle cable into the search box. It will bring up a list of items. Select the Diamondback Multi-Length for Dyna/FXR: http://www.harley-davidson.com/gma/g...bmLocale=en_US
After the item description there is a link called "How to Select the Correct Cable Kit" Click on it and it takes you to a table: http://www.harley-davidson.com/pna/p...bmLocale=en_US
Look up a Dyna Street Bob 2006-2008 and you will find stock length is 32.5" with a 90 degree bend for both throttle and idle.
Back to the search box; now enter Clutch cable. It will load a list of items. Select the Stainless Steel Braided Clutch Cable for Dyna/FXR: http://www.harley-davidson.com/gma/g...bmLocale=en_US
Look for the same "How to Select the Correct Cable Kit" after the item description. Click on it: http://www.harley-davidson.com/pna/p...bmLocale=en_US
Look up your bike and you will find 2006-2008 FXDB has a clutch cable with a total length of 68.69" (37.19" top half, 31.50" bottom half)
For the brake line, I was not able to get a stock length off of the website, but measured mine and added extra length based on the difference in bar height. I can tell you that stock Street Bob bars have 10.25" of rise. This is off of a similar HD web page, but I cannot find it now. A lot of people call the 12" mini apes, but they are not 12". I went from stock to 12.5" Wild Ones, and they are 2.25" taller. Good luck!
Old Oct 12, 2008 | 12:57 AM
jordanball33
man you are a life saver, is that dual throttle cable and dual idle cable, or single throttle cable and single idle cable on a street bob?
Old Oct 12, 2008 | 12:09 PM
BluBob's Avatar
BluBob
Single Throttle Cable, and a Single Idle Cable. It's two separate control cables, Throttle Cable is one, Idle Cable is the other. They are very similar but one has a smaller fitting where it mates into the switch housing. They are not interchangeable. Measure your brake line and add about 6" and you will be good. I think Jireh sells a 55" Russell for around $30 that would probably work.
morleyz
Mar 11, 2018 08:03 PM
supermanotorious
Sep 2, 2016 04:26 PM
ruckus4offroad
Feb 16, 2014 05:15 PM
95yj
Exhaust System Topics
Dec 28, 2012 11:19 AM
Sy101
Aug 30, 2012 11:08 AM
