LED Lights on gas gauge acting up!!? HELP
Old Oct 16, 2008 | 03:26 PM
118811fh's Avatar
118811fh
Default LED Lights on gas gauge acting up!!? HELP
HI Guys
2001 Dyna
I am on the freeway, had 3.5 blue lights when I left my house (4 Blocks away)
& notice 1 light now??? .5 miles then red light blinking!!!
I promptly get off and get gas...I am filling up and it stops at $4, I had gas I deduct it is the gauge, I feel better, much better
Anyone had this happen before?
Any advice...thanks
Old Oct 16, 2008 | 04:27 PM
HOGRIDA_06's Avatar
HOGRIDA_06
The lights on my gauge are worthless. Half of them burned out within 4 months. Be sure to reset your trip meter at fill up and refill at around 150 miles.
Old Oct 16, 2008 | 05:24 PM
LWOS's Avatar
LWOS
Mine lasted 15 months before they started acting up. In August I noticed exactly the same thing you did 118811fh. Heck, one time I filled up, The top center light never came on even though the gas was up to the rim, but the 6 bottom lights were lit. After 20 miles I noticed all of a sudden I had 4 lights, afte 20 more miles I had 2 lights!! What the Heck!!!! Then after 5 more miles I went UP to 3 lights indicating. The next time I filled up, I had two lights on the left, and two lights on the right......and 2 lights completely out in the middle. Anyway, since mine is still covered under warranty, I'm getting mine replaced without any expense to me, along with the flush mounted gas cap, which isnt sitting flush anymore either. This will be the second time that's been replaced.
So, I feel your pain. I always reset my trip odometer and know I usually get 47mph on country roads. When I hit 150, I start looking a Shell station.
Old Oct 17, 2008 | 09:58 AM
red devil's Avatar
red devil
Mine does the same thing only when I get low on fuel my last 2 blue lights jump back & forth between blue & red. Had the gauge about a year and usually when it turns red I have about a gallon left. But good advice from others always set your trip when filling up.
Old Oct 17, 2008 | 10:05 AM
118811fh's Avatar
118811fh
thanks guys for the explanations
The cap wedges into the tank right?
I was thinking about disconnecting it...don't like havig
The red light blinking, ańu problems doing that?
byersmtrco
Nov 3, 2018 11:53 AM
Mawwk
2014-2024 Touring Models
Nov 6, 2015 05:28 PM
rideneasyinNH
Oct 6, 2012 08:48 AM
FL-kruzen
Feb 18, 2012 09:43 AM
spydyr
Mar 6, 2011 06:00 AM
