Front end question
Old Nov 5, 2008 | 10:57 AM
roofer's Avatar
roofer
Default Front end question
I am replacing my narrow glide frontend with a wide glide frontend and the new frontend doesn't have the bearings and my question is can I use the the parts from the narrow glide or do I have to get new ones, I'm talking about the bearings on the stem. And my bike is a 2003 lowrider the frontend is from a softail standard I'm going with a 21 front wheel to
Old Nov 5, 2008 | 10:58 AM
07bobber's Avatar
07bobber
Personally i would use all new.
Old Nov 5, 2008 | 11:03 AM
roofer's Avatar
roofer
The bike only has 3900 miles on it that is why I thought I could go ahead and use them but would they work
Old Nov 5, 2008 | 11:24 AM
rounder's Avatar
rounder
they will work! to get the bearing on the stem, freeze it(stem and lower tree) for a couple hours... bearing will slide right on...
Old Nov 5, 2008 | 11:42 AM
roofer's Avatar
roofer
Thanks another question should I get the stock axle and spacers from a fxstd and use my hub and have it relaced to a 21 wheel or get a hub from a standard also Thanks
Old Nov 5, 2008 | 12:36 PM
jmpancoast's Avatar
jmpancoast
Your hub won't work. you will need a conical type hub from a WG or standard.
Old Nov 5, 2008 | 12:50 PM
roofer's Avatar
roofer
Thats what I thought Thanks
Wasta81
Jun 19, 2017 12:49 PM
Todd611
Wheels/Tires
Dec 1, 2013 06:24 AM
Todd611
Nov 30, 2013 09:14 AM
calvinbabb
Mar 29, 2013 08:02 PM
snacks63
Nov 4, 2010 09:52 PM
