i believe rbabos is correct.
i have a harley led gauge that i will be installing soon. it also has a gray wire and similar instructions.
it appears that the gray wire is nothing more than a voltage divider tap which will supply the speedometer low fuel connection with a constant voltage (about 3V). this probably keeps the speedo low fuel lamp off at all times, and you will need to rely on the informer fuel gauge only.
splicing will cause problems with the informer and the speedo lamp.
if you don't hook up the gray wire - the speedo low fuel lamp will stay on all the time.
