Narrow to wide project
Old Nov 10, 2008 | 03:05 PM
fxdllr's Avatar
fxdllr
Talk with WS6, he will help you,here is mine https://www.hdforums.com/forum/members/22727-fxdllr-albums-2160-low-rider.html
Old Nov 10, 2008 | 03:35 PM
drtheo's Avatar
drtheo
With the 21" wheel up front it really looks thin,with the wide glide front it will really look thin, that could be the look your going for. I just changed the rim out, and put new spokes.
Attached Thumbnails Narrow to wide project-dyna-pics-008.jpg   Narrow to wide project-dyna-pics-002.jpg
Old Nov 10, 2008 | 07:43 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by Gwjvw
Well i got me a 21in oem rim and tire from a 08 WG,Now i need everything else to turn my fxdc front end over to a wg front end!
For the people that have done this how do you like it? Is it the same as having a wg in the rake sense?
Where is the best place to shop for whatever else i will need?
Wide Glide rake is 34* in the steering neck and has 2* triple clamps for a total of 36*. Your bike has a 29* steering neck, and with the 2* Wide Glide triple clamps you will be at 31*. Info below should help, only other difference that I'm aware of is that the 08 bikes have a metric sized axle.
Originally Posted by WS6 Formula
Here's a couple of photos (before and after). Added 2* Wide Glide triple clamps, a Wide Glide 21" wheel, and 12" Low Profile Touring shocks. Original Low Rider triple clamps are 1 1/2*, so I only increased the rake a 1/2*.
More info below.
Larger photo here:
http://img136.imageshack.us/img136/69/beforeaftermarch2006febvg7.jpg
Larger photo here:
http://img56.imageshack.us/img56/7950/sundaymarch232008067100gi6.jpg
Here's what I used: 2006 Wide Glide parts; 21" wheel, upper and lower triple clamps, axle, axle spacers.
From a hardware store: 3/4" chrome spacers and 3/4" longer then original stainless Allen head bolts for mounting the fender, and stainless washers for shimming (.040" for the caliper & .090" for the rotor) to center the caliper over the rotor.
Use other existing hardware from your bike (axle nut and washer, triple clamp pinch bolts, head bearings nuts and washer, fender nuts, forks, etc.).
I bought the parts from Zanotti's back in June of 06.
Here are the Harley Davidson part numbers and Zanotti prices:
P/N 46700-06 Upper Triple Clamp.....$ 65.75
P/N 46386-06 Lower Triple Clamp....$139.83
P/N 40923-06 Front Axle..................$ 28.39
P/N 40926-06 RH/FRT Spacer.............$ 4.58
P/N 40927-06 LH/FRT Spacer.............$ 4.58
Total..$243.13
Update: 4/3/08
Axle spacers above are also available in a chrome tapered version P/N 41410-06 Chrome Tapered Front Wheel Spacer Kit $23.51
Original Wide Glide tire replaced with only 7,300 miles on it (Not much tread left). Replaced it with a Avon Venom AM41 90/90-21, widest tire (3.70") I could find that will fit the Wide Glide Profile rim.
Larger photo here:
http://img61.imageshack.us/img61/425...08104aaoo0.jpg
sped
Oct 22, 2018 10:04 AM
MadScientist323
Dec 18, 2012 03:10 PM
Muddyape
Dec 14, 2012 08:22 AM
rerelli
May 30, 2012 10:44 AM
turtleman57
May 31, 2010 12:45 AM
