Narrow to wide project
Old Nov 9, 2008 | 06:14 PM
Gwjvw's Avatar
Gwjvw
Default Narrow to wide project
Well i got me a 21in oem rim and tire from a 08 WG,Now i need everything else to turn my fxdc front end over to a wg front end!
For the people that have done this how do you like it? Is it the same as having a wg in the rake sense?
Where is the best place to shop for whatever else i will need?
Old Nov 9, 2008 | 07:22 PM
Roadman56's Avatar
Roadman56
The man to talk to is WS6 he has all the part numbers for the parts needed. My approach was a little bit different and I didn't use all Harley parts like he did. I have a three degree rake and non harley trees.
Attached Thumbnails Narrow to wide project-rc-ride-004.jpg   Narrow to wide project-rc-ride-007a.jpg
Old Nov 9, 2008 | 07:27 PM
devils haircut's Avatar
devils haircut
Bosken did this mod and listed all the part numbers in a post. He used after market trees and it cost WAY WAY WAY less than using OEM HD parts. Do a search.
Old Nov 10, 2008 | 06:13 AM
matt45's Avatar
matt45
Just intalled last week on my 2007 Dyna its not HD parts but look better (0° rake):
Old Nov 10, 2008 | 06:20 AM
rounder's Avatar
rounder
looks good.
Old Nov 10, 2008 | 06:44 AM
jamesrgarner's Avatar
jamesrgarner
Did you change the lowers or were you able to use the original?
Old Nov 10, 2008 | 08:54 AM
jsbridgew's Avatar
jsbridgew
I did the same thing following all the parts from WS6, with the exception of the tubes- i actually used the wide glide tubes, he didn't.
it's a nice rake... but if you lower the rear with progressive 11inchers, for example, lower the front if you can- i did mine in the trees for 1 inch... it makes it more of a slammed look and it performs better at higher speeds.
Old Nov 10, 2008 | 01:18 PM
Gwjvw's Avatar
Gwjvw
Do you have a side shot of your bike?..
What if i left my bike all stock and just threw on that 21in rim and tire from the wg,or would that look funny?
Old Nov 10, 2008 | 01:28 PM
JRK5892's Avatar
JRK5892
here is the thread that was posted about the parts list:
https://www.hdforums.com/forum/dyna-glide-models/280286-wide-glide-triple-trees-conversion-for-dyna-part-and-prices.html
Old Nov 10, 2008 | 02:51 PM
bosken's Avatar
bosken
Thanx Joe! Very simple and quick mod it is....
