Wide glide frontend
Old Nov 12, 2008 | 11:59 AM
roofer's Avatar
roofer
Default Wide glide frontend
I am putting a stock wide glide frontend on my 03 lowrider and keeping my 19" wheel so do you think I will need to install a lowering kit in the forks since I will be running a 19" wheel
Thanks for any help
Old Nov 12, 2008 | 01:36 PM
glide05's Avatar
glide05
since the lowrider is already lower than the rest of the dynas, you might want to lower the front. but try it stock first.
if the tubes are a bit longer than your stockers, that's really not a problem. i dont know the length diff between the LR front and the WG front.
you will have more clearance.
your bike will turn a bit slower.
your bike will lean over more when on the jiffy stand. I suspect that since the LR already has a shorter jiffy than all other dynas, yours is going to lean way over on the stand.
try it first - if you don't like it then lower it.
Old Nov 12, 2008 | 02:17 PM
rounder's Avatar
rounder
I think you will want to lower it an inch. I had to lower mine two inches and it is still tall. My headtube is 28ş though. with your headtube angle 1 inch will be good. you can do 2 to give it a more slammed look. Also the top triple tree sits lower than the stock 39mm front you have.. you'll see what I mean. This make the bike sit higher for the same length tubes.
Old Nov 13, 2008 | 10:40 AM
roofer's Avatar
roofer
Thanks for the info hey rounder what year is your bike and what kind of set up do you have your bike looks great. I think i will lower it 1"
joetom08
May 2, 2013 09:48 PM
bL33d
Jul 19, 2012 02:32 PM
ken ipock
Mar 22, 2010 10:28 PM
sickboy75
Feb 28, 2010 03:39 PM
baxter
Feb 17, 2007 01:22 AM
