Where does this torx screw go?
Old Nov 14, 2008 | 10:32 AM
JRK5892's Avatar
JRK5892
battery box bolt...
Old Nov 14, 2008 | 12:38 PM
mud's Avatar
mud
Originally Posted by KBFXDLI
After washing my bike...this torx screw shows up on the ground... looked everywhere..took off the air cleaner cover..nothing missing anywhere. Anybody have any ideas? It is the same size as the throttle body screws but none are missing.
Looks like a #8 self tapping.
May be screw for the anti rattle spring on clutch lever.
mud..........
Old Nov 14, 2008 | 01:44 PM
dyna mo's Avatar
dyna mo
derby cover!
Old Nov 14, 2008 | 10:41 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
None of the above. It is the same screw used on the AIT sensor and the other parts on the throttle body but they are all there.
Old Nov 14, 2008 | 11:17 PM
rdondes's Avatar
rdondes
I agree with anubiss. Put it in your tool box until such time as you figure out where it goes. Do as good an overall inspection of your bike as you can do, including pushing and pulling on things, and if you can't find out where it goes, don't worry about it.
Old Nov 15, 2008 | 12:59 PM
CRF's Avatar
CRF
throw it in the trash where all torx screws belong....
Old Nov 15, 2008 | 01:07 PM
Bluesssman's Avatar
Bluesssman
It is mine. Flew off the bike and I never knew where it went! Thanks for finding that little bugger!!!
Old Nov 15, 2008 | 01:14 PM
rbabos's Avatar
rbabos
Probably from the switch housings at the grips. Looks like one I took out a few minutes ago to lube the cables.
Look underneath the housings. One screw on top and one on bottom , each side.
Ron
Old Nov 15, 2008 | 01:26 PM
DannyZ71's Avatar
DannyZ71
Motor mount?
Old Nov 15, 2008 | 04:51 PM
rounder's Avatar
rounder
anyone other than you work on the bike?... they could have dropped it into the mysterious bolt eating part of the bike and it just regurgitated it.
