Where does this torx screw go?
Old Nov 15, 2008 | 06:24 PM
  #31
barfly's Avatar
barfly
6th Gear
what kind of coil cover do you have? I have one with a hidden bracket so that no hardware shows. There are three screws that hold the cover to the bracket from the bottom.
Old Nov 15, 2008 | 06:42 PM
  #32
Poisond 08 Fatbob's Avatar
Poisond 08 Fatbob
Talking
"Baffle screw?"
Yep,
It has us all baffled!
Old Nov 15, 2008 | 07:18 PM
  #33
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by rounder
anyone other than you work on the bike?... they could have dropped it into the mysterious bolt eating part of the bike and it just regurgitated it.
Yes, had the dealer do work last spring but they took the primary cover off and this screw is way too small. But my dealer has worked on it several times. I was thinking the same thing. As in the past they have done the stage1, replaced the fuel injectors, etc.
Old Nov 15, 2008 | 07:35 PM
  #34
paul s's Avatar
paul s
If anybody tells you ya got a screw loose just tell them yea but where does it go.
Old Nov 15, 2008 | 10:42 PM
  #35
DannyZ71's Avatar
DannyZ71
Got a neighbor that wound up pulling the cover off his transmission. When he did, he noticed 3 out of 5 screws inside it missing. How they got out of there is the mystery. May want to pull the cover off and check.
Old Nov 16, 2008 | 12:18 AM
  #36
ackman1968's Avatar
ackman1968
I bet at some point they dropped a bolt and couldn't find it then replaced it with a new one.
Old Nov 16, 2008 | 12:45 AM
  #37
bfreesun's Avatar
bfreesun
Are you just screwin with us?
Old Nov 16, 2008 | 06:05 PM
  #38
vet767's Avatar
vet767
I keep sayin, if there is no lockwasher, star washer, or spring washer, locknut of some kind, put loctite on it or it will come loose. Also, the only time I really worry about a leftover "whatever" is when I take it apart. Put it in a safe place with a tag that says extra, find a place for it" or you will darn sure forget why you saved it. OOPS, that's for me, I'm old and lucky I can remember my name
kainvamp
May 5, 2021 02:37 PM
nuttbaggerr
Mar 20, 2020 08:02 AM
mcrackin
Jan 28, 2018 09:07 PM
bobby5
Apr 25, 2010 08:29 PM
ggold
Feb 8, 2006 09:47 PM
