Help - what tool size?
Old Nov 19, 2008 | 12:51 AM
roy2008's Avatar
roy2008
Default Help - what tool size?
Can anybody advise what size of wrench should be uese for;
RIGHT AND LEFT REAR AXLE NUT 2008 DYNA?
I need to loosen these to adjust driving belt. A dealer told me it is 28mm for both. Can it be metric when all others are inch size?
Thank you!
Old Nov 19, 2008 | 06:28 AM
shimmon's Avatar
shimmon
oh yes it can be metric... i dont know what size wrench it is, have you tried all the wrenches in your collection on it? if so, just measure it with a tape or an adjustable if your going to go buy or borrow one... but i would suggest getting a set of larger wrenches...
Old Nov 19, 2008 | 06:55 AM
robertj74's Avatar
robertj74
they are 36 milimeter on my 08 FXDC.
Old Nov 19, 2008 | 11:20 AM
crabs's Avatar
crabs
Question metric
Have a look inside the wheel rim mine say MADE IN JAPAN.You will soon need a metric tool kit for these bikes.The brakes are metric to.
My 1991 Royal Enfield is a right mixture of sizes.And they differ from bike to bike.I think they just use whats around at the time they build them.
Old Nov 19, 2008 | 03:27 PM
roy2008's Avatar
roy2008
Thanks to all for your help. I did not know some parts are metric.....
Old Nov 19, 2008 | 04:41 PM
DGDyna's Avatar
DGDyna
If you are asking what size socket/wrench you need for an axel nut (both axel nuts) then you should probably take it to the dealer for ANY service issues.
Old Nov 19, 2008 | 04:43 PM
anubisss's Avatar
anubisss
Axle nuts are 36MM. I jsut use a large adjustable wrench on the other side.
Old Nov 19, 2008 | 06:14 PM
rockon's Avatar
rockon
Axle is 25mm, bolt is 36mm.
Barrier
Dec 21, 2013 11:25 PM
RidemyEVO
EVO
17
Jan 21, 2011 09:13 AM
Joe What
Mar 28, 2010 06:57 PM
bosken
Feb 5, 2009 02:59 PM
ccbm51
Apr 2, 2007 05:35 PM
