Need help, wrench socket inches size.
Old Feb 5, 2009 | 04:36 AM
bosken's Avatar
bosken
Default Need help, wrench socket inches size.
Gonna put in 2" drop ins, need the correct size of the wrench socket for the upper bolt..See pic
Don´t want to damage the bolt. Need exact socket.
Old Feb 5, 2009 | 05:40 AM
nolafishr's Avatar
nolafishr
Do you have Sockets? I would do a Test Fit and find the exact Size, Looks like it will be a Large Size. I do not know the Exact Size.
Old Feb 5, 2009 | 06:02 AM
Tele00's Avatar
Tele00
I just measured it on my 08 FXDC and its 1 3/8 " But being that there isnt a lot of height to the area, you may be better off with a wrench, many of the larger sockets are beveled a tad at the head and there isnt a lot of contact on shallow items like that , either way , be sure to have a bit of downward pressure to insure it won't jump .
Old Feb 5, 2009 | 02:21 PM
bosken's Avatar
bosken
Ok. I will remove the handlebar first,, think that a socket is the best. just using a wrench is risky..
Old Feb 5, 2009 | 02:53 PM
JRK5892's Avatar
JRK5892
1 3/8 it is my friend... as stated above your going to want to pull the bars... remember to torqe to spec when you put it back on... DO NOT wan to strip those... something i also do on chrome bolts is i put a piece of masking tape around the inside of the socket to help protect the bolt... it is so thin that it will still work no problem...
Old Feb 5, 2009 | 02:58 PM
bosken's Avatar
bosken
Great! And thanx for the tip on masking tape!
Old Feb 5, 2009 | 02:59 PM
paul s's Avatar
paul s
http://www.motionpro.com/motorcycle/partno/08-0139/
beanoboy
Feb 11, 2017 02:17 PM
TSD
Dec 28, 2015 04:45 PM
Barrier
Dec 21, 2013 11:25 PM
BKSinAZ
Aug 12, 2012 07:23 PM
bubba626
EVO
Apr 21, 2011 04:55 PM
