Maximum HP and torque?
Old Dec 5, 2008 | 05:24 PM
  #31
creekhed1's Avatar
creekhed1
I just put a Heavy Breather, Fuelpak and Short Shots on my FXDL and it's all I need. Plenty Quick but not so fast I'll get into...whatever...
Old Dec 5, 2008 | 05:30 PM
  #32
Herr Monk's Avatar
Herr Monk
Originally Posted by mudpuddle
I like my long stroke motor just fine with only 116 HP at 5500 RPM.
And,
I'd would like to hear more about this 9000 RPM FatHead motor.
Got links??
mud
Most people who like the Harley "feel" like the feel of long-stoke engines matched with tall gearing.
If all you want are big numbers, and that feel, then what you've got works.
Most people equate big numbers with big performance though. 116 hp @ 5500 rpm doesn't make a particularly quick bike (outside of air-cooled HD and HD knockoff land).
I can't remember where I got the 9000rpm number. But I know people who are tuned/built to make power up to 7000rpm, which is what I was suggesting.
Old Dec 5, 2008 | 06:03 PM
  #33
mud's Avatar
mud
Well I gotta say you win as a master of spin.
and, as to the 9000 #,
You throw this out, then forget.
I've never heard of that, but I sure would be interested.
mud
Old Dec 5, 2008 | 06:06 PM
  #34
Herr Monk's Avatar
Herr Monk
It was an HD tech at the dealer, I remember now. Said the A model Twin Cams could run up to 9000 without falling apart (maybe not long term). Like I said, 7000 is reasonable, and I know a few.
What am I spinning?
Old Dec 5, 2008 | 06:18 PM
  #35
mud's Avatar
mud
What am I spinning?
What a joke.
I would even settle for a link to an 8000 RPM built FatHead.
mud
Old Dec 5, 2008 | 06:36 PM
  #36
Herr Monk's Avatar
Herr Monk
Is there a point?
You don't believe it's possible?
What follows from that? I can assure you, with the proper modifications, it's at least possible for a short period of time. But I'm not sure what you're getting at.
The bottom line is, if you want a quick Twin-Cam, you should not increase the stroke, rather, move the dimensions toward squaring the bore and stroke, and pick cams and other components that function well at a high-rpm. Then, gear the bike down.
Old Dec 6, 2008 | 12:45 AM
  #37
SURFOR Chop's Avatar
SURFOR Chop
Here's a question:
The following table shows a comparison of 96 and 88 with same Big Bore kit and then with putting the Max SE jugs available through the MoCo on an 88 ... would give same CID as 96 with the Big Bore kit, but with less damage to the cylinders at the same RPM--presumably allowing for a longer lasting hi-output motor. Does this make sense?
Bore Stroke CID
Twin Cam 96 3.750 4.375 96.641
Big Bore 96 to 103 3.875 4.375 103.191
Twin Cam 88 3.750 4.000 88.358
Big Bore 88 to 95 3.875 4.000 94.346
Max H-D Jugs with TC 88 Stroke 4.060 4.000 103.570
Old Dec 6, 2008 | 03:05 AM
  #38
CaptGoodvibes's Avatar
CaptGoodvibes
I wouldn't mind a evolving my bike into a snappy canyon-carver. I don't cruise when I'm out riding. I ride very aggressive and like to hit the mountains as much as possible. I guess if I had to try and equate my vision to a car, it would be a late 60's ponycar style of bike. Not really muscle car but the sportscar racing series. That probably sounds lame but that's what I envision in a motorcycle.
galaxyfe
Engine Mechanical Topics
Aug 22, 2015 07:33 PM
brberk
Exhaust System Topics
16
Feb 28, 2013 12:54 PM
dan conner
Dec 12, 2011 07:55 AM
DesertBum
Sep 20, 2007 11:14 PM
Vector
Aug 10, 2007 03:14 PM
