Internal wiring
Old Dec 4, 2008 | 03:18 PM
Double00Aught's Avatar
Double00Aught
Default Internal wiring
Just put the Street Slammers on the Superglide and want to fish the wiring harness through the bars. After studying it for some time I'm not sure where to start. The diagram shows fishing from the top to the bottom. The harness feeds into the frame, no where to disconnect from the looks of it. The top side appears to be permanently connected to the switches as well.
So how's it done? Worst case scenario is to pull it to the stealer with a failed look on my face, and I want to avoid that at ALL costs.
The new bars look f*#%ing bad *** too, I'll post pics once it's all finished.
Old Dec 4, 2008 | 03:41 PM
tweakin's Avatar
tweakin
On the frame under the fuel tank and above the front rocker cover there is a plastic cover that covers a opening in the frame where the wires are hidden. You can pull the wires out there and get to the quick disconnects for the controls. You can elevate the front of the tank to make this easier. I unbolt the tank (front and back) unhook the quick release fuel line from the fuel pump (like an air tool) and slide the tank back a couple inches. The fuel transfer line in the front stays connected.
Once you get to the wiring quick release you can take it apart and push out each individual plug (make sure you draw a diagram of where the wires go) If you dont want to mess with the quick connect plugs you can always cut and solder.
Old Dec 4, 2008 | 03:52 PM
JRK5892's Avatar
JRK5892
here are a few links to help you... be sure when you drill those holes they are PERFECTLY SMOOOOOOOTH!!!!
Internal wiring bars
https://www.hdforums.com/forum/dyna-glide-models/14129-evolved-to-the-apes-done-thanks-new-pics.html
https://www.hdforums.com/forum/dyna-glide-models/68079-how-to-do-handlebar-internal-wiring.html
ext: http://www.jpcycles.com/productgroup...9-9D98ED920065
Old Dec 4, 2008 | 03:56 PM
Double00Aught
Excellent, thanks. I'll give that a shot.
Old Dec 4, 2008 | 03:58 PM
Double00Aught
https://www.hdforums.com/forum/showthread.php?t=14129
https://www.hdforums.com/forum/showthread.php?t=68079
Thanks Joe. These bars are pre-drilled and also have rubber grommets to help reduce stripping one of the wires. This is going to be fun
Old Dec 4, 2008 | 04:51 PM
lee's Avatar
lee
just finished my bars tonight used welding wire to pull leads through which i wrap in clingfilm have fun
Attached Thumbnails Internal wiring-redbob-054.jpg   Internal wiring-redbob-047.jpg
Old Dec 4, 2008 | 05:18 PM
Double00Aught
Is that a braided wrap? I like it.
Old Dec 4, 2008 | 05:35 PM
JRK5892's Avatar
JRK5892
you can get it a cableorganizer.com
Old Dec 4, 2008 | 05:39 PM
lee's Avatar
lee
yes braided all wires & fitted ignition to centre console whilst i have it stripped,just cleanes things up
Attached Thumbnails Internal wiring-redbob-062.jpg   Internal wiring-redbob-071.jpg
Old Dec 4, 2008 | 05:50 PM
Double00Aught
Dam dood, that's sharp, I really like it.
