Internal wiring
Old Dec 5, 2008 | 04:54 PM
Babs's Avatar
Babs
Are you this far???
http://i69.photobucket.com/albums/i7...s/IMG_1032.jpg
As seen in this thread:
https://www.hdforums.com/forum/dyna-...e-install.html
Old Dec 5, 2008 | 04:58 PM
Double00Aught's Avatar
Double00Aught
Originally Posted by Babs
I am not. I have a 6 pin Molex connector that I need to figure how to either get the wires out of, or cut it off and then splice them after fishing.
Old Dec 5, 2008 | 05:03 PM
Babs's Avatar
Babs
One thing.. Just looking at deutsch and molex (not sure which you're running there I think deutsch).. be very aware to avoid if possible having to recrimp new ends.. if you have to recrimp a new end on the wire.. I was surfing JP cycles and their crimp tools are like $200 to $400+. yyeeeeeaaaooow! dang that's expensive.
Old Dec 5, 2008 | 05:05 PM
Babs's Avatar
Babs
If it's the exact same as that pic in that thread, he used a pick tool to pry done (gently) the tabs, in order to free the wire from the plug. disclaimer, if one of you other guys that have actually done this can chime in.. I'm flying by wire as I haven't messed specifically with that kind of plug but looks easier than the taillight connectors for sure.. large enough to work with.
Old Dec 5, 2008 | 05:10 PM
Double00Aught
I see, so each wire is freed individually from the connector then? I'll probably need to look at it with fresher eyes tomorrow. A buddy and I worked on it for a few hours this afternoon and it stumped him and I both.
Old Dec 5, 2008 | 05:11 PM
Double00Aught
This is a male connector, are each one pushed out in reverse carefully I'd assume?
Old Dec 5, 2008 | 06:43 PM
dpriest's Avatar
dpriest
If a splice is done right.. you should be fine. There's an art to it.
Pretty confident. Im good at sh*t like that. By cutting and splicing were I did, I was able to conceal and protect all the splices inside the bars. If u extend the wires from the connector thats inside the frame,( like the kit from JP does) the slices wind up outside the frame.
I think a solder joint done right, is as close to a perfect connection as u can get. Would have been nice to have all the color coded wires though.
Old Dec 5, 2008 | 06:55 PM
dpriest's Avatar
dpriest
Yes, one at a time. The HD manual has a section on working with these. Do u have one? If not, do a search on this forum. I do belive there is a thread on it Good luck and just take your time.
Old Dec 5, 2008 | 09:37 PM
Naz_Man's Avatar
Naz_Man
I cut and spliced mine and got all the joints in the bars and that was 3 years ago and have never once had a problem.
I did the complete job in 3 hours alone, cake i say!
If I can help you any just yell!
Donnie
Old Dec 5, 2008 | 10:02 PM
Double00Aught
Got it, right side is finished!! Working on the left now!!
