Clutch adjustment???
Old Dec 6, 2008 | 10:54 PM
Frog33's Avatar
Frog33
Default Clutch adjustment???
Hey All,
I may have made a rookie mistake!! I purchased the Boss blades for my 08 SG. I have large diameter skull grips,, and it seems the combination is preventing me from fully disengaging the clutch. I am wondering if I can adjust the clutch to compensate,if so how hard is it going to be, or return to a lever that doesnt come back so close to the grip. Thanks for the help!
Old Dec 6, 2008 | 11:10 PM
PeeTuneYa's Avatar
PeeTuneYa
First, could you get N easy? Say you have to yank of the foot lever or take your hand to find neutral? Then it is not going to be easy to adjust without some detail.
OK, say you can catch N no problem. Then we want to go to the cable and run the adjuster all the way so you do not see any threads on the mid adjuster cable.
No, go to the center adjust pin is if this is multi-plate, then there is a center screw with a piggyback nut to hold it in place. You break the nut, run it into the push rod so as not to raise the pressure plate but just kiss the push rod with the adjust pin screw. Now, back it off 1/4 turn, tighten the piggy nut; go to the cable and take out any stack at the mid adjuster on the cable.
Find almost zero gap at the lever an perch. Then try pulling in the lever and see if you found N any cleaner?
Old Dec 6, 2008 | 11:16 PM
Frog33's Avatar
Frog33
Nah wouldnt go easy at all,, sounds like the best bet is going to be a different lever...I appreciate the info.
Old Dec 6, 2008 | 11:22 PM
PeeTuneYa's Avatar
PeeTuneYa
OK, now we have the pressure plate that might not be flat. So, now it is a deep adjustment, meaning; to get the pressure plate back to flat, you need to add more fiber or thicker fibers/steels so it pushes the pressure plate back to a flat spring sorta.
Once you have that flat, you then do the screw adjust. But being you say it is hard before the mod is the new lever will not help, maybe. If you get the pressure plate flat, you can find N without pulling the lever in and touch the grip or your accessory, (that is in the way of a normal pull the lever in).
AUTOT3K
Jan 15, 2019 12:05 PM
Pommerntat
Mar 9, 2015 07:02 PM
mdbhunt4
Mar 19, 2010 07:23 AM
dkfxr
EVO
Sep 3, 2009 12:35 PM
Capt_Locutus
Aug 20, 2008 02:08 PM
