Ready for powder
Old Dec 20, 2008 | 05:40 AM
larazauk's Avatar
larazauk
Default Ready for powder
Going to start stripping the front end down as I want to powder coat the fork lowers and triple trees, rims and hubs.
Never done this on a harley and was wondering if there is anything I should look out for or any tips to make the job easier?
Thanks guys
Old Dec 20, 2008 | 05:50 AM
powdercoater's Avatar
powdercoater
Be sure to remove the lower bearing from the triple tree and your sealed bearings from your hubs! You'll probably have to replace the tree bearing and dust plate but the cost is minimal. The hub bearings must be pressed out with a special tool. If you don't have one find a shop that can do it since you'll ruin the hubs trying to pry them out.
Good luck with your project!
Old Dec 20, 2008 | 07:52 AM
larazauk's Avatar
larazauk
Thanks for that! will the hub bearings be reusable or should I replace them? only done about 4000 miles on them
Old Dec 20, 2008 | 08:39 AM
rounder's Avatar
rounder
should be reusable...may not hurt to replace if they have rust.
Old Dec 20, 2008 | 10:15 AM
JRK5892's Avatar
JRK5892
as long as you take them out strait and put them in strait you are fine... check for flat spots on them... i re used all but 1 of mine when i did my wheels... do not forget to do your show cap on your front wheel as well , you will see what i mean when you start to pull them apart
Old Dec 20, 2008 | 09:39 PM
thedonthere's Avatar
thedonthere
Default 21" Road Winder on 06 Bob
You can use uour bearings over if you're careful when you remove them. I removed the ones in my 21" raodwinder that I machined down to fit my bob. The bearings came out fine and went back in fine.
Old Dec 20, 2008 | 10:09 PM
Tripped1's Avatar
Tripped1
Whoa, did you remove the rear shocks and put a solid bar in place?
Old Dec 21, 2008 | 12:07 PM
dpriest's Avatar
dpriest
Ouch!!! Hey looks great. What did you have to do to get the 21" roadwinder to fit? I was told by the dealer it wouldnt fit. So I had to put the 19" on. which has a totally differant look. I would have gone with 21" if I had the choice.
Old Dec 21, 2008 | 12:15 PM
thedonthere
Default struts
Yes I wanted to lower it as much as possible. I have a set of EMS shocks for it that are 10.75 " The struts are 10". I just ordered some 10" shocks for it and I will post pics as soon as I install them. I have lowered it 1.5" front and rear then changed the front wheel from a 19" to a 21 ". It rides so much better now it's like having a totaly different bike!.
Old Dec 21, 2008 | 12:29 PM
thedonthere
Default 21" roadwinder
I bought the set of roadwinders I have off craigslist for $500.00 + shipping. They came off a 2007 SE Dyna with 200 miles on them. The rear went right on . I just had to pull the primary and change the belt so I could use the matchimg pully. The front hub was too wide so I had to take .500" off both sides and move the bearing races in the same amount. I had it done where I work so the total cost for machining was $27.00 for a bottle of whisky! It was well worth the hassel as you can't buy a 21" roadwinder for a Dyna. No problem with the front fender either. It fits nice and close to take the "dirt bike" look away.
WMX124
Aug 30, 2020 10:12 PM
Jersey Drew
Jan 13, 2015 03:46 PM
Mark_FLHTCU
Feb 17, 2014 07:18 PM
wiegs
Apr 13, 2009 11:10 PM
AAA88
Jan 21, 2009 12:33 PM
