I believe the odd handling characteristics of the Dyna Chassis are due to the fact that the swingarm mounts/pivots on the transmission case, which is bolted directly to the engine and both the engine and transmission are rubber mounted. There is a dgreee of this movement that is relayed to the swingarm. That is what the True Track is designed to deal with. The FXR was considered by many to be the best handling HD ever made. It was also rubber mounted, the difference was the swingarm pivot was mounted to the frame not the swingarm.
I believe the odd handling characteristics of the Dyna Chassis are due to the fact that the swingarm mounts/pivots on the transmission case, which is bolted directly to the engine and both the engine and transmission are rubber mounted. There is a dgreee of this movement that is relayed to the swingarm. That is what the True Track is designed to deal with. The FXR was considered by many to be the best handling HD ever made. It was also rubber mounted, the difference was the swingarm pivot was mounted to the frame not the swingarm.Tech23
Well I couldn't agree more. To the peeps here that say nay, or don't get it, I don't get (READ: Understand) them (you). And, I'll admit I bought my first and only harley without realizing that the swingarm pivot was mounted to the tranny. When I did find out about it, I was a bit alarmed, and suddenly aware why my bike swam like a fish (best way I can describe it), most noticeably here in the OC on the long, higher speed sweeping freeway interchanges, which I am extremely familiar with from regular travel, and from pushing the limits with on my last bike (pictured). So, anyone who is comfortable with their swingy not being frame mounted, and has no problem with it, prolly rides in straight lines.
I tested the bike before and after the install. Having held an AMA pro license, I understand suspension and chassis setup. I ran the test on two different types of curvey paved surfaces. One was smooth blacktop with some tight corners, elevation changes and long sweepers. The speed limits on the road vary from 20 MPH to 55MPH in the straights. I ride the road freuently and with the Sputhe, I could carry much more speed through the corners and other than a little tire flex, which happened before the install also, I could hold a line much better and the suspension could do its job better because it is not getting sideloaded as much when the isolators are flexing. The other road is a CA highway that I drive every day. It is in poor condition and in a straight line the bike feels about the same but on a rain grooved turn/overpass I could carry much more speed(110 MPH compared to 89 MPH). I still experienced tire flex but not as bad. My next test is my Radial tire swap/30 tooth trans pulley.
I need to send Mudpuddle my write up on my dual disc conversion and some photos of my bike.
I didn't realize the swingarm doesn't bolt to the frame on the Dyna until I started reading about this True-Track. I was surprised. If the engine/transmission is solid mounted and stressed, I could see where bolting the swingarm to the tranny case probably wouldn't be a problem. But on a rubber mount, where the engine/tranny is NOT stressed, it makes no sense to me whatsoever to do it that way.
-From the site-
"Without PosiTrac our test bike was noticeably twitchy at about 90 mph. Above 120 or so the instability was positively nerve racking. After installing the PostTrac the bike tracked like it was on rails up to an indicated top speed of 133 mph."
if these are the speeds that are improved by this device, I wont have any need for it, if I am entering a turn at 90, its because I am in a race car and wont need to worry about my bikes handling much less at 133?!?!?! for F**k sake! come on folks
-From the site-
I doubt my dyna will do 133, and even if it could, I would 't be taking it there. I gather from the quote they were taking about a 'test' bike, probably on a test track. Nonetheless, as others have indicated, you don't need to to run any where near 133 to experience the wallow.
I know, I have experienced the wallow a bit on my 08, it freaked me out a little the first time, now I dont mind it at all, I was just being a smart ***, its a problem I have.....
I have to be honest, I bought my Wide Glide also not realizing the swingarm was mounted to the transmission case. I didn't realize it until I was at the York PA. assembly plant during open house a few years back and witnessed the assembly station where the swingarm was FIRST attached to the transmission case.....then the swingarm/transmission assembly was attached to the engine which was already in the frame at this point. I think HD owes Dyna owners free stabilizers as a retro fit, to cure this rubber band handling characteristic we have all learned how to ride around. Don't believe you have learned to ride around this handling trait, get off your Dyna and ride a rigid (engine) mounted Softail one time.
