Question about RPMs
Old Dec 28, 2008 | 02:21 PM
Pepsimayn's Avatar
Pepsimayn
I've always wondered what "long distance/steady RPM" is by definition. I want to get to the 1000 mile service as quickly as possible (within 2 weeks) because I've got a longgggg drive from MI to NC.
Is there a general rule of thumb for highway miles during break in?
Old Dec 28, 2008 | 02:23 PM
BlueBobber07's Avatar
BlueBobber07
So in a nut shell, what would be the best way to help with the 2.79 ratio? Change the rear sprocket to a 70 tooth or the front to a 30 tooth? Maybe both that would give you a 3.15 (06 Dyna) and you could use your stock belt right?
Old Dec 28, 2008 | 02:42 PM
bberck's Avatar
bberck
Just got back from a ride on mine so I checked out the RPM's
5th gear at 70 was at 2850
Old Dec 28, 2008 | 02:54 PM
Gary7's Avatar
Gary7
2850 @ 70 in 5th? That sounds more like 6th.
Old Dec 28, 2008 | 03:04 PM
bberck's Avatar
bberck
I was in 5th so unless my tach or speedo is off.
Old Dec 28, 2008 | 03:12 PM
Gary7's Avatar
Gary7
That may be about right, I guess, if 70 is 2500 rpm in 6th. But based on your numbers, that would make 60 around 2500 rpm in 5th. Is that what you saw?
Old Dec 28, 2008 | 03:13 PM
rayfinseats's Avatar
rayfinseats
I've always wondered what "long distance/steady RPM" is by definition. They don't want you to break them in on the highway. They want acceleration adn decelleration, like riding around town. My brother always said break them in like you are going to ride them. I think breakin is overrated. The rings probably break in in the first 100 miles and the bearing probably 300 miles.
Old Dec 28, 2008 | 03:27 PM
Shag67's Avatar
Shag67
I took it easy on my '09 Street Bob. Made sure I didn't take it up over 95 mph for the first 1000 miles.
Old Dec 28, 2008 | 03:44 PM
bberck's Avatar
bberck
Ya I went back out to make sure I wasnt crazy lol
It runs about 2500 at 70 in 6th gear.
Here is a pic of 70 in 5th. Looks like closer to 2900
Old Dec 28, 2008 | 04:06 PM
Gary7's Avatar
Gary7
Now that's what I call "hard evidence."
I'd say that 60 in 5th is definitely around 2500 rpm based on what you're seeing at 70. Do you remember if that's what it was?
