Mini Ape Hangers
Old Apr 14, 2006 | 12:53 AM
Rocket Man's Avatar
Rocket Man
Default Mini Ape Hangers
I thinking about putting the Mini Ape Hangers on my Super Glide. H-D makes some for Sportys, FXD and FXR's. Part No. 56563-95. Has anyone put these on thier FXD? What cables did you change out? I heard you all you need to change is the brake line, and all the other cables and wires are okay. Comments?
Old Apr 14, 2006 | 01:06 AM
veniculum's Avatar
veniculum
Default RE: Mini Ape Hangers
I know for sure some people have done that...I've seen the pictures on this site. (And they look great!) I bet if you search around a bit, you'll find them....if they don't post first.
Todd
Old Apr 14, 2006 | 01:52 AM
Fat_06's Avatar
Fat_06
I replaced all the cables because I went with braided stainless, but I think the bars feel much better than the stock ones...
Old Apr 14, 2006 | 04:17 AM
bobcowan's Avatar
bobcowan
I replaced mine with mini-apes from Wild1. They have the same rise and pull back as the stock Wide Glide bars, but the angle of the hand grip is a lot more ergonomic. A very comfortable bar. It's also a thicker/heravier bar, so it dampens vibration better than stock.
Since it's essentially a stock replacement, you use stock replacement hose and cables.
The new stock WG bars are fatter, and look better. But you can't use them on a SG because the clamps and risers are the wrong size. Wild1 gets around that by necking down the bar at the clamp area.
[IMG]local://upfiles/6263/2FEE6B04197E4CBA9A8BE7586A1B3250.jpg[/IMG]
Old Apr 14, 2006 | 10:30 AM
rh8234's Avatar
rh8234
I put HD Mini Apes on a couple weeks ago (2003 FXD). I had to replace clutch cable and front brake line. I got the ones for a stock wide glide and they fit perfectly. The stock FXD throttle and idle cables work fine but you will need to re-route them so they do not run between the tripple trees. (I did change mine thouge with stock length braided stainless cables.)
Old Apr 14, 2006 | 10:54 AM
Mrkicks's Avatar
Mrkicks
I had mine done by the dealer and had braided cables and a tach put on at the same time...along with a little chrome nick knacks. Heres a pic.
[IMG]local://upfiles/4175/4B97643BD11C4F9BA2EA38A9F0C42E0A.jpg[/IMG]
[IMG]local://upfiles/4175/DA3F191B2AB94568BA87419FD576CF42.jpg[/IMG]
Modo
2018+ Softail Models
Apr 3, 2019 12:02 AM
Rusty Needles
Mar 28, 2015 09:36 PM
atxfxdb
Mar 2, 2014 08:53 PM
Brad2064
Jan 11, 2011 11:17 AM
FxdFred
Jul 6, 2009 04:24 PM
