removing tank emblems
Old Jan 8, 2009 | 09:15 PM
ZEALOUS_DRAGON's Avatar
ZEALOUS_DRAGON
Exclamation Removal made easy
Apply Goo B Gone along the outer edge. Let it soak in for several minutes. Then use the dental floss (I used a very thin fishing line) go up and down in a saw action. While starting in the front and pulling back towards yourself, have someone else lightly lift on the edge that you have already cut. Good Luck.
Old Jan 8, 2009 | 09:56 PM
BuffaloRider's Avatar
BuffaloRider
Originally Posted by db252
Get it good and warm with a hair dryer and then go for the dental floss technique. The heat will soften it up for removal.
+1...You have to heat it up first... Then use Goo Gone after you get them off.
Old Jan 8, 2009 | 10:41 PM
HD Jake's Avatar
HD Jake
I used dental floss, I think I ended up doubling it up, heated up the emblems and they came right off, WD-40 was the ticket to get the glue off
Old Jan 8, 2009 | 10:57 PM
stevja1's Avatar
stevja1
Mine were a pain to get off... used dental floss, WD-40 and a blow dryer. If I were to do it again, I'd get dental floss, a couple of sticks to wrap the floss around, (instead of my fingers), and a heat gun. Heat seemed to make the biggest difference.
Old Jan 8, 2009 | 11:34 PM
lhcstreetbob's Avatar
lhcstreetbob
Default tank emblems
I just did mine last night. the none fuel side came off no problem with heat and a little goo gone but the fuel side kicked my a$$. I had a bunch of fine swirl scratches in the paint under where the emblem was. i had to take it to my buddy to buff it out.He said something about the fuel in the tank not liking the heat from my heat gun making it harder to come off.I dont know if i buy that but it looks good now after the buffing.
Old Jan 9, 2009 | 12:04 AM
Gwjvw's Avatar
Gwjvw
Pull it off by hand then pick the bigs parts off then use gas,thats it!!!! And gas doesnt hurt a think trust me! I have had it on my tank for 3 days stright and didnt know it,all it did was ruin my leather a bit! Paint is perfect!
Old Jan 9, 2009 | 03:03 AM
RockyTopRider's Avatar
RockyTopRider
stren 14lb test doubled with vice grips, heated with hair dryer. came right off.
Old Jan 9, 2009 | 03:24 AM
ko4qc's Avatar
ko4qc
I used a wire saw to remove the but-ugly stock emblems from my 07 FXDB...one like you find in a survival kit.got mine at Lowes I think....place the wire under one end of the emblem and,keeping both ends angled away from the tank,saw the emblems off...works like a charm and the wire never contacts your tank.Also,the emblems come off in perfect shape...:>)
Old Jan 9, 2009 | 06:43 AM
BUSCHA's Avatar
BUSCHA
Originally Posted by tom lipke
the background is red.
Great, that's the one I like. If you get them out and they are in good shape please PM me.
Old Jan 9, 2009 | 08:37 AM
sniper77's Avatar
sniper77
I just took mine off.
I didn't mess with the dental floss. I just used a heat gun on the low setting, got it good and warm and, pulled them off slowly. What little bit of adhesive left on the tank I used gooBgone and was finished in five minutes.
