Synthetic fluids
Old Jan 15, 2009 | 06:35 PM
dagored11's Avatar
dagored11
Default Amsoil
I switched to Mobil 1 synthetic when I had my Sporty. I noticed the engine seemed to run smoother and it definitely ran cooler. When I got my Low Rider I switched to Amsoil on the recommendation of my mechanic - both in the engine and the tranny. Much smoother shifting. In my opinion it's worth the few extra bucks.
JA
Old Jan 15, 2009 | 06:48 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Switched to Syn-3 at my 1000-mi [dealer] service. All I can say is that I FEEL better knowing it's in there, especially pulling that slow, steep switchback grade in 105 degree heat climbing up towards Yosemite. I did my own service at 5K and 10K; went with the same in all 3 holes. Can't say I notice any difference. I still lost my inner primary bearing at 3900-mi. I'll probably opt for something thicker for the tranny next time...Clunk!
Old Jan 15, 2009 | 07:07 PM
Blk and Chrome's Avatar
Blk and Chrome
It's worth it, synthetics keep the heat down, used it in my racecars for years
Old Jan 15, 2009 | 07:08 PM
luckyB's Avatar
luckyB
I switched to Amsoil at 1k. I think it's worth it.
Old Jan 15, 2009 | 08:36 PM
archergodwin's Avatar
archergodwin
Ran HD dino till 500 miles, changed out the oil and filter with more dino. At the 1K I had the dealer change to Syn-3. I changed to Mobil-1 v-twin 20/50, redline heavy duty shockproof in the tranny, and regular dino in the primary at 3K, and that's where I'll stay for every 5K on.
Old Jan 15, 2009 | 08:45 PM
NewHarleyGear's Avatar
NewHarleyGear
Default Amsoil only!
Try the severe gear in your transmission...you will tell a difference. Less "kluck" when you go into 1st gear and smoother shifting.
Old Jan 15, 2009 | 09:13 PM
mphamrick's Avatar
mphamrick
The guys I run with say it runs cooler and the bright side is you only have to change the oil every 5 K miles.....
Old Jan 15, 2009 | 09:31 PM
bugzapper's Avatar
bugzapper
Use synthetic in all 3 holes here too. Seems to be smoother shifting and cooler running. Anything I can do to extend the life of the engine and tranny is worth the few extra bucks at oil change time.
Old Jan 15, 2009 | 10:14 PM
BigJfxdwg's Avatar
BigJfxdwg
I went to Royal Purple, best damn oil ever. Runs smoother, shifts smoother, even got better gas mileage (no ****). Well worth the money if the bike runs better.
Old Jan 15, 2009 | 10:17 PM
rockon's Avatar
rockon
I had the stealer put in synthetic at the 1000 mile tune up....it still sounds like a sewing machine. That was the only maintenance they'll do, after this I'm gonna be doing all of it, so it'll probably be Mobil1 when it comes time to change again.
