Easy Brackets
Old Jan 22, 2009 | 07:04 PM
togfish's Avatar
togfish
Question Easy Brackets
Has anyone here used the Easy Brackets saddlebag mounting system on a late model Dyna? What did you do for a turn signal relocation kit? How did it all turn out? Thanks
Old Jan 22, 2009 | 07:34 PM
ernajlb's Avatar
ernajlb
I used the one from the EasyBrackets website. I'm pleased with it, and it seems to be a solid piece.This is the best picture I have right now, not a closeup, but you get the idea. Picture #1 in my album has a different view, but still not a close-up.
Old Jan 22, 2009 | 07:45 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Easy Brackets on my 02 superglide, for the model I used the HD relocation kit. When the bags are carrying a light load there is some rattling from them. Some have put a thin washer behind one button to introduce a slight bind reducing the rattle. I haven't done this myself, just passing it along.
Old Jan 23, 2009 | 07:25 AM
8541hog's Avatar
8541hog
I have them on my 05 WG, I ended up making a custom mount of sorts, using several different pieces. Lots of ways to do it based on your bike.
Old Jan 23, 2009 | 08:33 AM
efciv's Avatar
efciv
I used the HD turn signal relocation kit cause I had a gift card at a dealer. Watch the video on the Easy Bracket site, and it shows removing the "plug" from the tail light exposing the "pins" on the turn signal wires. With the HD kit you also have to cut those pins off the wire to thread the wires through the turn signal stalk. Then to re-crimp the new supplied pins, it takes a special "barrel roll crimper" which I could not find. Use the Easy Bracket kit, and save days on the install.
Old Jan 23, 2009 | 03:46 PM
rounder's Avatar
rounder
Do you already own the bags?
www.leatherpros.com
www.bossbags.com
Best bags around and beautiful quick detach system. Lockable too.
The easybrackets will move your bags out to the side creating a gap viewed from behind.
http://www.cyclevisions.com/bag-mounting/barebacks/ ... these are nice for H-D saddlebags. Don't lock though.
Old Jan 23, 2009 | 03:52 PM
formike56's Avatar
formike56
I have the easy bracket's without using the relocation kit
Deathtrap
Apr 16, 2012 06:53 PM
dwg1956
Jun 12, 2009 09:07 AM
strich
Oct 26, 2007 07:33 PM
ghostlight
Mar 8, 2007 11:17 AM
WVICEMAN
Sep 27, 2006 03:27 PM
