just started today it vibrates rel bad at 45 to 50 mph in fith gear.It feels like the front tire is almost hopping i checked the tire psi and im at 31 warm tire and the tire says 41 cold is it the motor mount or wut do i do????
no evry thing is ther no egg.It almost feels like your lugging the engin but 50 to 55 in fith is normal i think i might have some lose motor mounts or somthing i checked my oners manuel and it says not to tighten them down are they suposed to be tight?
Mine vibrates when switching to 5th at 45 to 50 mph, too. A sudden misaligned belt sound happens at the same time. 5th is definitely wierd on my bike. Maybe they will give it some attention at my 1st (1000) mile service.
mine does it in fourth fith and six i was going down the interstate at 60 and 65 in sixth gear and it seems to vibrate or bounce like it feels if you lug the engine.I even get it to do it at the fifty mark and i pull the cluch in and coast and it still does it any info ? the top motor mounts are tight do you think the botom two rubber mout ones are loose?
What kinda makes me mad is that Harley sells you a bike and a bogus break-in plan to go with it. Plus, a proud new owner naturally wants to follow the correct break-in procedure. They say, "Don't go over 50mph for the first 50 to 100 miles, then don't go over Xmph and don't hold it at one speed for a long time." It's also in the owner's manual not to lug the motor or over rev it during break-in. How the hell are you supposed to hop on a new bike with NO TACH and with plenty of wind noise and know when to shift into your higher gears. 1st, 2nd, and 3rd are easy but the wind noise gears 4th, 5th, and 6th are impossible to discern on a new bike. I was lugging my motor bad on my maiden voyage home but didn't know it until I got used to the correct sounds and vibes over the next two weeks. Right now I stay in gear until the vibrations disappear and then start to come back due to high rpm, then I switch. Usually I don't bother with 6th until around 63mph, and 5th makes it's squealing noise at anything lower than about 53 mph.
squealing? hmm that might be bad id get that checked out mines mor like the front tire is hopping or out of balence but it just started at 780 miles.I could be lugging it too but fith gear at 50 didnt do it before ? im boggled
