Installing Nostalgic Grips?
Old Jan 23, 2009 | 07:50 PM
Handycam's Avatar
Handycam
Default Installing Nostalgic Grips?
I bought a pair of HD "nostalgic" grips for my Sporty and never got around to putting them on. Good thing, since I traded it for the 07 FXDB.
I know they fit this bike too, but I am unsure how the installation might differ. For the 08 Sporty, there's no glue needed; the left one is fixed in place by a ridge and groove. and the right one I remember people warning me about losing the throttle ferrule and to put cardboard in the brake lever to keep it slightly pressed.
Is it the same process to change the Dyna's grips? Anything else I need to know?
Old Jan 23, 2009 | 09:35 PM
Robert Le Gras's Avatar
Robert Le Gras
Sounds like the same process to me.
Old Jan 23, 2009 | 10:00 PM
08fxdf43202's Avatar
08fxdf43202
Yea, thats right... I use a short #6 or #8 srew instead of the cardboard.
Old Jan 24, 2009 | 08:22 AM
doxbike's Avatar
doxbike
My sister didn't use glue on her left grip and it slipped on her during a hard corner.
I also had a set of grips that I didn't put on the sporty (Kuryakyn Iso-grips) that I just put on the FatBob.
One difference with the sporty vs the big twin-on the sporty you can see the throttle stops behind the A/C for cable adjustment. On the 96'er you can't, so be sure to mark the visible threads on the adjusters so you can get it back where it was, or you'll have to pull the A/C.
Old Jan 25, 2009 | 07:20 PM
Handycam's Avatar
Handycam
What do you mean by this? On the Sporty changing grips was pretty straightforward, this sounds much more risky...
Old Jan 25, 2009 | 07:27 PM
BluBob's Avatar
BluBob
I didn't adjust the throttle stop on mine. I loosened the adjustment nuts on both the throttle and idle cables, removed the grip (don't loose the ferules or the throttle lock shoe) and replaced the grip. Then I adjusted the throttle and idle cables as per the service manual, and was done. The only time I was down behind the air cleaner was to feel the tension when adjusting the throttle cable to make sure it wasn't pulling against the throttle stop. It should just tap it, not ram up against it. That way you don't have a lot of tension on your throttle cable when at WOT. Easy day.
Old Jan 25, 2009 | 08:07 PM
pennetta's Avatar
pennetta
I backed the two adjuster bolts off the same amount of turns, when I tightened them I just did it the same amount of turns back.
Old Jan 26, 2009 | 11:47 AM
Kushtaka's Avatar
Kushtaka
6th Gear
Same process-- I've installed the grips on a sporty and my Fat Bob. No glue needed if you install correctly. Just follow the instructions.
blackpullet
May 18, 2010 10:26 AM
Tri glide 10
Jan 23, 2010 09:02 AM
wolverine66
Apr 2, 2008 08:26 AM
cajunman831
Jul 3, 2006 02:08 AM
HD Renegade
Feb 14, 2006 12:07 PM
