some softails are lighter than some dynas...(like a nighttrain vs fatbob). rider weight may have as much a factor as the small difference in bike weight as well. I wonder if one can really tell the difference in a couple horsepower or ft-lbs of torque.
Dynas do have higher published torque than the softail. does this torque get lost in our rubber mounting system vs the rigid mount on the softail?
I don't believe H-D publishes the rear wheel torque.
This may be a dumb question, but is there a way to get a balanced fly wheel for a dyna? Would it cause any sort of additional problems?
The balance shaft in the B engine is a counter-rotating weighted shaft that negates the engine's natural imbalance and thus smooths it out some. I don't think there is any way to retrofit one to an A engine. The crankcases are different.
In Harley's Screaming Eagle Pro Racing parts catalog, they post dyno charts for various engines in both stock and various SE configurations. http://www.harley-davidson.com/wcm/C...p?locale=en_US
Stock 96" Twin Cam values at the rear wheel are a max of 78FtLbs @ 3,500RPM and max RWHP of 63 @ 5,000RPM
since softails have heavy counterbalancers on there crankshafts and dynas dont, do dynas have more horsepower ? im a 1st time poster so hello.
Just my 2 cents..... It's the same as when you install a steel billet aluminum flywheel in your favorite hot rod. The lighter flywheel (like a Dyna) will make the engine seem as though you magically gained a bunch of HP due to the fact that the horsepower isn't eaten up trying to spin up a heavy flywheel (ie: "B" engine), when infact the HP hasn't changed one bit. The down side is driveability and fuel economy at speed. With the lighter flywheel, engine speed changes more dramatically with every small change in throttle position and road conditions, whereas the heavy flywheel "coasts" through small changes as if they didn't occur. The heavy weight allows the energy "stored" in the mass to help maintain constant speed. That is why the flywheel was developed to begin with (and just happened to be the perfect place to mount the clutch and spin with a starter). If you have ever removed the HUGE flywheel from a CAT 3516 generator, you would see my point and they don't have a clutch.
When I changed from the steel flywheel to an steel insert aluminum one on one of my '71 Dodge Hemi cars, if I were in a lower gear and took my foot off the gas, the compression of the 11.5 ratio pistons would nearly lock up the back wheels. Great for drag racing, but sucked for just driving around. And gas milage went from 6.5 mpg to 4, but with 645 HP, who cares about that.
Same physics apply to the TC "A" and "B" engines. "A" lighter flywheel = better acceleration, rougher . "B" Heavier flywheel = better streetability, smoother. But does not change actual HP, if all things are equal, just feels like it.
I don't think that's correct. The B and A engines have the same flywheels, it's just that the B engines have an additional counter-rotating weighted shaft in the crankcase that is driven off the crankshaft. The extra HP it takes to constantly turn this big hunk of steel does reduce the available HP and TQ at the rear wheel.
Actually, the added weight of the counter rotating weight does equate to that. Add mass (weight) and therefore more stored energy. Anything driven off or connected to the crankshaft works on the same principal. Remove this chunk of steel and then all things are equal. Just precieved HP differs due to it being gobbled up by spinning the mass of the counterweight, but the stored energy is available on the "B" engine when throttle and road changes are presented, whereas that stored energy is not available on the "A" engine.. 6 of one, half a dozen of the other.
All I was saying was that the engines are basically the same, but the added mass presented advantages (smoother operation) as well as presenting disadvantages (horsepower available to the rear wheels).
