dynas more power then softies?
Old Jan 26, 2009 | 01:18 PM
ronny c.'s Avatar
ronny c.
Default dynas more power then softies?
since softails have heavy counterbalancers on there crankshafts and dynas dont, do dynas have more horsepower ? im a 1st time poster so hello.
Old Jan 26, 2009 | 01:21 PM
lowrider966's Avatar
lowrider966
NOt too sure bout' the HP...but we are faster (lighter)!
Old Jan 26, 2009 | 03:55 PM
bberck's Avatar
bberck
Welcome to the forum.
I have always heard they have about 5 more HP but not sure if thats correct or not.
Old Jan 26, 2009 | 03:58 PM
Gary7's Avatar
Gary7
The specs listed on the HD web site show the B engines have less torque, so one could presume they have less HP, too.
Old Jan 26, 2009 | 04:08 PM
dyna rider's Avatar
dyna rider
Default Dyna Power
"A" motors have more torque because of the lack of counterbalances. That coupled with a lighter overall weight makes them faster when both are still stock.
Old Jan 26, 2009 | 04:20 PM
Herr Monk's Avatar
Herr Monk
Yes, they have more power. They also have much more potential under modification than the Softails because they can be made to rev higher without blowing apart. If you're going to drop cash to mod the engine, but want it all "down-low" and useless, it's pretty much the same. The weight will be the bigger issue. But if you want to build a slightly higher-reving engine, then the A model is the way to go.
Old Jan 26, 2009 | 04:27 PM
squale147's Avatar
squale147
id say yes
Old Jan 26, 2009 | 05:10 PM
07bobber's Avatar
07bobber
Sure ..........
Old Jan 26, 2009 | 05:43 PM
Sammi's Avatar
Sammi
The "A" engine, coupled with black paint, make a Dyna significantly faster.
Sammi
Old Jan 26, 2009 | 06:56 PM
rockon's Avatar
rockon
More torque and better power/weight ratio.
