Pads rubbing?
Old Jan 27, 2009 | 12:37 PM
FUQUA's Avatar
FUQUA
Default Pads rubbing?
Posted this in the Tech forum no response, i know you guys wont let me down.
06 Dyna superglide....just installed chrome DNA rotors, took a few 15min rides no issues at all. Then it was pretty warm the other day went from place to place for a few hours, on the way home the front brakes started to moan when i would stop. In the morning when i got up and was pushing my bike i could hear the pads rubbing! Is there something wrong ? How do i stop this?
__________________
Old Jan 27, 2009 | 12:40 PM
JRK5892's Avatar
JRK5892
sounds like you do not haev pad greese on the back of the pads, put some high temp on there and you will be golden... also bear in mind there is a film on new rotors that you need to remove with alchole bfore you install them (it is used to protect the metal from corosion when they are waiting to be sold... you can also burn it off while they are on the bike... you can slightly hear the pads on the rotor typically on all harleys
Old Jan 27, 2009 | 01:30 PM
hardrider's Avatar
hardrider
A sure fire trick I have always used is to buy a roll of gasket material from an auto parts store and glue it to the back of the pads, never fails. If JRK or my advice still fail to rectify the problem check the centering of the disc. Loosen the bolts on the rotors pull the lever in and secure with rubber band or what have you, inspect the disc to see if it has pulled away from the hub and shim if necessary. Hope this helps. KEVIN
Old Jan 27, 2009 | 01:33 PM
JRK5892's Avatar
JRK5892
huh gasket paper huh! good trick there!!!
Old Jan 27, 2009 | 01:40 PM
FUQUA's Avatar
FUQUA
Thanks guys, did not know there was a substance on the rotors that needed to be cleaned. I'm gonna start with the pad grease and see what happens then i'll work from there thank you.
Old Jan 27, 2009 | 03:10 PM
rounder's Avatar
rounder
did you change to new pads too? The old pads are matched/worn to the old rotor so a little brake noise can occur till they seat smooth to the rotor you now have.
Old Jan 27, 2009 | 03:28 PM
FUQUA's Avatar
FUQUA
Nah, didn't even think about changing them......had a lot of pad left, the wear pattern never even crossed my mind...oh yeah
Rounder, i painted my lowers they look amazing thanks for the help...i'll post pics later.
Old Jan 27, 2009 | 03:50 PM
rounder's Avatar
rounder
awesome on the lowers. Glad I could help.
Old Jan 27, 2009 | 05:40 PM
JRK5892's Avatar
JRK5892
dude that is your issue then! your pads need to be swapped as well... just get some lyndall golds on there use a bit of high temp pad greese on back of them and pop em in there... shoudl take care of your issues... i did not even think to ask that... good ey Rounder!
smokindave
Jan 3, 2022 06:16 PM
s.ga.rider
Aug 3, 2014 05:07 PM
tx-skydiver
May 13, 2010 09:26 AM
Mr. Lucky
Apr 3, 2010 06:27 PM
FUQUA
Wheels/Tires
Jan 27, 2009 07:40 PM
