Askin for pics on SG riser mods
lookin for somethin to bring the bars up a little closer, tried those softail standard bars, but no joy. don't wanna break the bank!
where you able to use the stock cables with that setup?
What bars are those?
my personal bike is a night train, 79's FXS and 51' FL. But I've been babysittin this 06' FXD for my dad for the last year while he lives in cleaveland. he says I can ride it all I want. so I toss my wife on the SG, but those bars aren't right for her either.
supplies:
chrome plumbing pipe
fender washers
push cap
hardened bolt
how you do it...
measure how high you want to go up.
pull out the riser bolt and measure that... the diff between your bolt and how high you want to go will tell you the size of the new bolts you need to buy
go to the hardware store and pick up a piece of chrome plumbing pipe (the kind that they have under sinks)
then go over to the nuts and bolts section and get a 2 push caps
now get the same riser bolts you have in there now just a bit longer (to match the height you want) be sure that they are hardend
looking at your bolt and chrome plumbing pipe, find the fender washers that will fit around the bolt and almost fill the pipe diameter (they are close but now going to completely fill it from what i have found)
now go home...
find the center of each push cap you bought and drill out a hole that will fit the bolt
measure out in fender washers how high you want to go up on the rise, take this size and cut the chrome tubing (before cutting tape it off with packing tape to keep the chrome from flaking)
now you just put it all together, run the new bolt up from the bottom of the tree, put on all the fender washers, put your chrome tube with push cap over those and then screw that right into your stock risers... BOOM riser extensions for 5 bucks!
class dissmissed...
any questions hit me up... they work great and i have done this on a ton of bikes
dont have to spend big bucks to get cool looking crap! remember if you can buy it you can build it better!
