99 FXDX rear shocks
Old Feb 11, 2009 | 10:04 AM
red69camaro's Avatar
red69camaro
Default 99 FXDX rear shocks
Hi everyone, I'vee been lurking for ages and finally thought I would get involved a little more.
Right now I have 12.5 inch rear shocks that are shot. I have been thinking about going to 11.5 but progressive doesn't make them in the 412/418 models. They make 11s though.
Is anyone running 11s? Any fender rubbing? how about the scrapping on corners?
I weigh 200 and I rarely carry a rider.
Thanks
Old Feb 11, 2009 | 07:00 PM
last saint's Avatar
last saint
Stay away from the 11's. Too short and will ride like ****.
Old Feb 11, 2009 | 08:36 PM
madden23's Avatar
madden23
Here's my take on rear shocks, the more travel the better.On a Dyna I'd stick to 12 1/2(stock) or 13" and then there's the big choice of which brand. Here's how I rate them.
1) stock: crap
2)Progressive 412 better barely 225.00Pr.
3)Progressive 440 noticeable improvement 480.00 Pr.
4)Works Performance single rate better than 440's tailored for your weight 469.00 Pr.
5)works Performance dual rate 649.00 pr. better still
Now we start getting to the ones that will keep you firmly planted, supple ride whole different ballgame.
6)YSS Z series self adjusting gas shock, preload, rebound adjust 399.00-589.00
7)YSS G series self adjusting shock with piggyback reservoir preload rebound and compression adjust 659.00-849.00 pr
8)Penske 1000.00+ per pair preload rebound some models compression adjust.
Feel free to argue how I rated them, pick the one that suits your budget. I feel that all of them are better than stock, some WAY better. I guess it all depends on your priorities,my first priority has always been suspension first,brakes second, motor work third and bling last.
Old Feb 11, 2009 | 08:50 PM
madden23's Avatar
madden23
Forgot to add the more expensive shocks are rebuildable and will last a lifetime, they should be rebuilt about every 30K, they are custom tailored for your weight and riding style, and are very adjustable, they won't ship in a day,so expect a 2 week wait. I'll wait for the experts to chime in. I'm just some guy who expects my Harley to handle well, sound good, and look good.
Old Feb 11, 2009 | 09:29 PM
last saint's Avatar
last saint
You did a great job catagorizing them! VERY GOOD JOB!!!!
Old Feb 11, 2009 | 09:51 PM
07fxdb's Avatar
07fxdb
funny you should ask riding an FXDX - I put FXDX shocks (I believe 2001) on my St. Bob: . Along with V-rod internals up front, I have a very good handling motorcycle. Scrape a set of pegs down to metal each run up or down the Skyline Dr and Blue Ridge pkway...
Old Feb 12, 2009 | 09:05 AM
red69camaro
Thanks Guys...
I have 30k on the stock shocks and they are past being shot. I think I'll go with the 12". It has a pretty good stance.
Old Feb 12, 2009 | 09:56 AM
grbrown's Avatar
grbrown
Be aware that the ride height on the FXDX is a little higher than other models, giving more ground clearance. If the front forks are also longer, then fitting short shocks may mess up handling. Seems a shame to fit shorter shocks on the sporty Dyna!
Old Feb 12, 2009 | 10:35 AM
rounder's Avatar
rounder
yup. I would do 12.1" black trackers from works performance. dual rate springs.
Old Feb 12, 2009 | 08:59 PM
fxdxruss's Avatar
fxdxruss
Thumbs up
Hi
I still have the stock shocks have read a little and one thing that stood out was, when lowering shocks are used you change angles that have an effect on handeling. My 2cents,when I upgrade my rears will put on shocks that have the stock ride height . Did put in works front springs and have been pleased with the ride so far.
Russ
