Oil Leak on '07 Dyna
Old Feb 13, 2009 | 04:44 PM
BluBob's Avatar
BluBob
Default Oil Leak on '07 Dyna
I tried a search, but "oil" and "leak" bring up a lot of stuff, and I am no Boolean Black Belt. I noticed an oil leak after I rode about 3 miles down to the store today. I have seen very light seepage here before, but not enough to tell where it was coming from. Today, after I shut it off and noticed it there were tiny air/oil bubbles coming from the vertical seam near the base of the cylinder. The end of the yellow line shows where I saw the bubbles. The bike is an '07 that I picked up new in Aug of '07, so it's still under warranty. I just wanted to know if anyone had an idea of the cause and possible nutroll I am in for. I checked my oil, and it has not dropped on the stick, and I don't have any marks on the floor. After cleaning the underside of the bike, I would say it is maybe 1/4 ounce. Thanks for any help.
Attached Thumbnails Oil Leak on '07 Dyna-wide-view.jpg   Oil Leak on '07 Dyna-close-view.jpg
Old Feb 13, 2009 | 04:56 PM
07bobber's Avatar
07bobber
i have the same thing but its not as wet as yours....there isnt anything between that seem of the case so i dont know what it is???
Old Feb 13, 2009 | 05:16 PM
Phrogman's Avatar
Phrogman
That's where the two halves of the cases clamp together. I'd take it into the shop. It's on 07 so should still be covered by warranty. You've got a minor leak, but it is a leak.
Old Feb 13, 2009 | 05:21 PM
hogcity5's Avatar
hogcity5
Either its leaking from between the cases or possible the o ring on the bottom of the jug let go?
Old Feb 13, 2009 | 05:35 PM
BluBob's Avatar
BluBob
Which way does that o ring lay? It seems like it is leaking from the vertical seam between the two cases. It's still under warranty through July, but I want to know what is going on before I take it in. I have had some good and bad experiences at the dealerships before, and have no service experience with this one.
Old Feb 13, 2009 | 05:40 PM
Curlybill's Avatar
Curlybill
I think that is called a base gasket. One of Harley's common problems. I have a 96 EG that is weaping soon to be leaking. My mechanic told me it would be $750.00 to do both cylinders.
Old Feb 13, 2009 | 05:42 PM
Shred4204's Avatar
Shred4204
take it in...get it fixed before summer...
I had a new motor put in at 400 miles dues to porous castings..
Old Feb 13, 2009 | 06:06 PM
mud's Avatar
mud
BB, the bubbling from that vertical mating surface.........
Only fix is to split the crankcases and reseal.
Major disassembly.
I've seen a few.
mud
Old Feb 13, 2009 | 06:44 PM
BluBob's Avatar
BluBob
Major disassembly.
Mr. Puddle,
I just got off the phone with the service dept. at a nearby HD dealer, and he told me much the same. I need to find time to get it. Am I looking at any problems with the warranty because of the PCIII, Slip Ons, and Big Sucker? I know that a Stage I isn't the cause, but I would hate to eat this one because HD decides to stiff-arm me on the warranty. The tech said it would most likely not require parts, but just a re-bonding of that vertical seam.
Old Feb 13, 2009 | 11:29 PM
archergodwin's Avatar
archergodwin
I'm thinking that would be a stretch to blame the leaking on a tuner, different intake and pipes.... :| The dealer would have to prove all that caused the leaking, to not cover it under warranty.
