Help! need help adjusting a clutch pack.
It is a standard thread on mine, an '07 six speed. I did mine with the bike in second gear and the wheel on the ground once. I did it on a lift with a friend holding the rear brake once as well. The higher gear you put it in the harder it will be to turn the rear wheel, but 2nd worked for me. You have to break the nut loose before you can do anything with the hex bolt. I used a breaker bar to loosen it, then a socket with a vise grip on it to tighten so I could keep a hex on the hex bolt.
On the cable adjustment, when you turn the adjuster to extend the cable housing, you are taking slack out of the cable. Mine is a standard thread as well.
72-120 INCH-LBS (6-10 ft-lbs) for jam nut
84-108 INCH-LBS (7-9 ft-lbs) for the cover screws
1/4 turn back from where I started to feel resistance". I was able to hold it with a vice clamp and a socket to get it tightened while holding the allen in the same spot.
I've tightened the cable again and played with it a little, but it seems like the clutch is way out on the handle (barely have to squeeze to engage) and I would like it back a little. Any ideas with out taking the clutch apart again?
If I do take the clutch apart again, do I need to tighten, or loosen the pack?
Any help would be appreciated the manual tells you what to do but doesn't explain how that effects the clutch. I think I need experience for that.
As far as the clutchpack goes: If you turn the allen screw further in against the resistance it has the same effect as engaging the clutch, that is to say it will slip. I know because I accidentally adjusted it a half turn IN instead of OUT, locked down the nut, and test rode it. The clutch slipped going up a hill under hard throttle. That being said, you may want to re-adjust it to a 1/2 turn out (instead of the 1/4 you have now) to give you a little more grab, requiring the clutch lever to come in more to engage the clutch.
For the lever, I would go with the nickel gap method and call it good. The clutch lever (and cable) should have no tension on it when not engaged.
For what it is worth, a few guys have mentioned that after having their bike serviced the clutch felt different. My guess is that any slight change on something you muscle memorize like that seems greater than it really is. There is an acceptable zone of adjustment, and from one end of that zone to the other probably varies a lot in terms of "feel".
I hope this makes sense, and please anyone who has something to add or correct on this one, do jump in. If it was me, I would ride it as long as the clutch grabbed and the bike was moving well before the lever came all the way out.
