Front turn signals/relocation kit
Old Feb 20, 2009 | 05:38 PM
BUSCHA's Avatar
BUSCHA
Default Front turn signals/relocation kit
I just did some mods on my bike, and I am not happy with the harley front signal relocation kit. The turn signals stick way out. See here:
I found that Kuryakyn has some nice brackets and turn signals. See here:
Has anyone done this? Also do you have pics of Kuryakyns small and large turn signals? Most pics I found are way up close, so I can get a proper idea.
I also think that harley has similar relocation brackets for 49mm forks. Is anyone using these? Pics? Thanks!
Old Feb 20, 2009 | 05:59 PM
jmpancoast's Avatar
jmpancoast
Go to the "Under Fifty Buckes" sticky. There is a relocation mod there using the ball mounts which is the OEM signal bracket on your clutch perch. Drilled the mounting hole from its 5/16 size to 3/8. You can pcik up an additional ball mount from the dealer for $7.00.
Old Feb 20, 2009 | 06:44 PM
BUSCHA's Avatar
BUSCHA
Thanks for the info, I'll check it out.
Old Feb 20, 2009 | 06:57 PM
Wonderbob's Avatar
Wonderbob
Check this out. It's got to be the cheapest fix. I had the same problem and used these. My buddy at the dealer found them. I'll look for the P/N.
Attached Thumbnails Front turn signals/relocation kit-dsc_0098.jpg   Front turn signals/relocation kit-dsc_0099.jpg
Old Feb 20, 2009 | 06:58 PM
lowridernj's Avatar
lowridernj
got this relocation kit for my 2008 from Rivco $40 shipped. worked great.
Front turn signals/relocation kit-006.jpg
Attached Thumbnails Front turn signals/relocation kit-006.jpg
Old Feb 20, 2009 | 07:08 PM
BUSCHA's Avatar
BUSCHA
Thanks. I think it would look cool (but perhaps be illegal etc.) to set them up like in the pic in the openning message, if the space between the forks allows. See also here (back again's night train, one of my favorite bikes in hdforums):
Old Feb 20, 2009 | 07:26 PM
JayFromPa's Avatar
JayFromPa
JP Cycles has a set that mounts like the above ones on the trees.
21.95 last time I checked.
Old Feb 20, 2009 | 07:28 PM
BUSCHA's Avatar
BUSCHA
Thanks Wonderbob! I just noticed your message.
Old Feb 20, 2009 | 07:46 PM
Fang13's Avatar
Fang13
J P Cycles....Nice 21......Scoots looking good.
Attached Thumbnails Front turn signals/relocation kit-front.jpg
Old Feb 20, 2009 | 08:11 PM
creekhed1's Avatar
creekhed1
I used the Kury kit...love it! (not pictured in my Sig)
