New Apes
Old Apr 23, 2006 | 02:11 PM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
Default New Apes
Picked up some new 16 inch chubby apes for my Wide Glide yesterday at a swap meet, going to look great! Now have to get the new cables etc.......any suggestions on measuring out the new lenghts I would need? I see alot of cables that I could just order 6 inches + over stock, which is basically what I am doing, have 10 inch apes now.
Also, any good places that have eletrical extension paks?
Thanks
Old Apr 23, 2006 | 04:52 PM
JonHanna's Avatar
JonHanna
Default RE: New Apes
Can't wait to see them.
Old Apr 23, 2006 | 05:32 PM
103FLHX's Avatar
103FLHX
I have 16's on my Wide Glide.
I have the longest Stainless clutch cable Harley has & it "bowstrings" with the bars fully turned.
Good Luck with the Apes!!!
Old Apr 24, 2006 | 12:58 AM
Hog_fever's Avatar
Hog_fever
Sean,
There are so many variables when trying to find the correct wiring extensions. For example, I replaced my stock 10" apes with Wild 1 Chubbies 10" apes and needed almost 10' extensions! How can that be? Well, they have a much wider base and are wider end to end. Dont know what bars you got but these are things to consider. I got HD extensions, they have connectors on both ends so it's a simple hook-up. Cost about $12 each. As far as cables go, My bars were 4' wider at the grips than my stock bars so I went with 2' over on all the cables and they fit perfect. Good luck, Your bike is gonna look great with those 16's!
Old Apr 24, 2006 | 05:49 AM
SPRINGER's Avatar
SPRINGER
16" apes on your bike, can't wait to see the pics. Should look great.
Old Apr 24, 2006 | 11:38 AM
Sounder's Avatar
Sounder
Good luck with the install, Sean. Can't wait to see the result.
Old Apr 24, 2006 | 01:37 PM
HDWG's Avatar
HDWG
Got the eletrical extension done, used my own wire and made the splices inside the bars.......everything works Getting ready to pick up my new cables and hopefully will have it done this afternoon, at least most of the way
Old Apr 25, 2006 | 10:23 PM
HDWG's Avatar
HDWG
Okay, here is what I have so far, gotta little more to due, fluids, bleed brakes, make sure all is tight
16 inch apes, 10 inch sissy bar.......the mods for the 06 season
Old Apr 25, 2006 | 10:24 PM
HDWG's Avatar
HDWG
Old Apr 25, 2006 | 10:25 PM
HDWG's Avatar
HDWG
