Wideglide triple trees
Old Feb 24, 2009 | 09:30 PM
redheadfred's Avatar
redheadfred
Thumbs up Wideglide triple trees
Are 06 wideglide forks 49mm like the Streetbob ? If so I should be able to swap the triple trees on my streetbob to wideglide trees and run a 21" wideglide or softail front . Any help will be appreciated
Old Feb 24, 2009 | 09:40 PM
glide05's Avatar
glide05
you might be able to do this .....
not sure if it's been covered before ......
Old Feb 24, 2009 | 09:47 PM
redheadfred
Smile triple trees
I just looked it up , they are 49mm and I got some part#s on some trees to give me about 2 degrees more rake if anyone is interested . Make it alittle easier than relacing a wheel I think
Old Feb 24, 2009 | 11:02 PM
SURFOR Chop's Avatar
SURFOR Chop
huh ... ?
Old Feb 24, 2009 | 11:07 PM
WS6 Formula's Avatar
WS6 Formula
Yes, see below
Originally Posted by WS6 Formula
Here's a couple of photos (before and after). Added 2* Wide Glide triple clamps, a Wide Glide 21" wheel, and 12" Low Profile Touring shocks. Original Low Rider triple clamps are 1 1/2*, so I only increased the rake a 1/2*.
More info below.
Larger photo here:
http://img136.imageshack.us/img136/69/beforeaftermarch2006febvg7.jpg
Larger photo here:
http://img56.imageshack.us/img56/7950/sundaymarch232008067100gi6.jpg
Here's what I used: 2006 Wide Glide parts; 21" wheel, upper and lower triple clamps, axle, axle spacers.
From a hardware store: 3/4" chrome spacers and 3/4" longer then original stainless Allen head bolts for mounting the fender, and stainless washers for shimming (.040" for the caliper & .090" for the rotor) to center the caliper over the rotor.
Use other existing hardware from your bike (axle nut and washer, triple clamp pinch bolts, head bearings nuts and washer, fender nuts, forks, etc.).
I bought the parts from Zanotti's back in June of 06.
Here are the Harley Davidson part numbers and Zanotti prices:
P/N 46700-06 Upper Triple Clamp.....$ 65.75
P/N 46386-06 Lower Triple Clamp....$139.83
P/N 40923-06 Front Axle..................$ 28.39
P/N 40926-06 RH/FRT Spacer.............$ 4.58
P/N 40927-06 LH/FRT Spacer.............$ 4.58
Total..$243.13
Update: 4/3/08
Axle spacers above are also available in a chrome tapered version P/N 41410-06 Chrome Tapered Front Wheel Spacer Kit $23.51
Original Wide Glide tire replaced with only 7,300 miles on it (Not much tread left). Replaced it with a Avon Venom AM41 90/90-21, widest tire (3.70") I could find that will fit the Wide Glide Profile rim.
Larger photo here:
http://img61.imageshack.us/img61/425...08104aaoo0.jpg
Old Feb 25, 2009 | 06:37 PM
Teagan's Avatar
Teagan
Is this a 25mm axle or a 1" axle
Old Feb 25, 2009 | 06:50 PM
WS6 Formula
It's a 1" axle, as noted above, parts list is for a 06 Dyna. Only difference I believe is the axle and spacers for 08 and up are 25mm.
Chrome spacers: http://www.harley-davidson.com/gma/g...bmLocale=en_US
Old Feb 25, 2009 | 07:19 PM
jackyl's Avatar
jackyl
here is a set on ebaY 66.00. jackyl
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Old Feb 25, 2009 | 08:33 PM
Teagan's Avatar
Teagan
Does anyone have the part number for the 08' (25mm) Wideglide axle?
Old Feb 25, 2009 | 08:46 PM
Teagan's Avatar
Teagan
I think I found it, is it 41547-07A?
