Harley's woeful suspension
1) front. 15W fork oil. works performance or race tech springs( race tech are geared for your weight, works have spacers you can orient to increase or lessen spring duration, especially the triple rate spring kit, accomplishes the same thing) both work. Racetech emulators or Ricor IAS valves, the goal is to keep the front end planted, stock is bouncy, excessive brake dive, stock Showa shocks suck, you want to isolate chassis and wheel movement.
2) stock motor mounts allow too much lateral movement, Sputhe or truetrac upgrade works.
Both are fine.
3) You want to buy shocks geared for your weight, with more than just preload adjustment, at a minimum a single clicker(rebound) if you've got money to spare a double clicker(rebound and compression) This is where most people cheap out, you are not going to get good rear shocks for 400.00 or less. Plan on spending at least 650.00 or more, possibly 1300.00 for a good pair. YSS 366 series, Penske and Ohlins are all good.
4) fork brace, good thing for pre 2006, not so critical after the 49 mm fork upgrade.
Ok products to avoid, if you want good handling, progessive 412 not so good, progressive 440, slightly better, works rear a notch above, progressive frontsprings(I'll sell you a pair), but these are only my opinions. Peace.
I got a set of rear shocks scheduled to arrive Thursday, lready have the tiple rate front Works. Also have the True track,,will instakk this weekend as well.
I certainly agree re: the front springs, the stock ones were really too soft...hope the rear shocks make as much difference.
I think that the suspension needs depends on what you expect of the bike. For those of us that don't ride the bike hard and run it on the edge the suspension seems fine. For the people like the OP, they most likely push the bikes and want to know it will be there when needed. I'm not one that notices the little nuances so I have not went for major upgrades.
