SERT calibration tables
Old Mar 3, 2009 | 10:36 AM
guzzishop's Avatar
guzzishop
Question SERT calibration tables
Pards,
I installed V&H big radius (2-into-2) pipes with Thunder Monster baffles (P/N 2002 -- not the quiet ones) and a SE heavy breather stage I A/C on my '09 Street Bob.
The 2009 SE Pro Racing Parts catalog says the Pro EFI Race Fueler only works on 06 - 07 Dynas, which is why I purchased the more expensive SERT with cables/software.
Two problems with the SERT:
1. There are no calibration tables for aftermarket stuff, only SE products. Is there any correlation between the available calibrations and my specific (aftermarket) configuration?
2. I don't have an Internet connection in my garage, and it appears that I need one in order to update the SCI firmware.
Anyone have experience using the SERT?
Mucho appreciado!
Old Mar 3, 2009 | 11:02 AM
red devil's Avatar
red devil
Your local dealer will have maps that they can put in for you. More than likely they have dynoed a bike with your set up before and have it saved. Your best bet is to have it dynoed and fine tuned to get the most out of it. Your set up was identical to mine before I did my motor. You should pull around 76hp & 94tq
Old Mar 3, 2009 | 11:42 AM
JRK5892's Avatar
JRK5892
you can adjust the sert to work for anything you hae full access to all your tables! I love my sert... hooks right to the lab top and go! Eric came by and tuned min in... he did a KILLER JOB!
SOCALHD
Aug 18, 2013 07:10 PM
SonicRising
Mar 21, 2013 02:26 AM
griffin94
Mar 11, 2011 11:19 AM
Jimbo59
Apr 3, 2008 12:15 PM
Caston
Mar 18, 2006 04:45 AM
