Shortshots concern
Old Mar 3, 2009 | 06:20 PM
joejack's Avatar
joejack
Default Shortshots concern
So I ordered a PC IV, the quite baffles for my shortshots and a Big Sucker A/C today. I took my heat shields off so I could install the quite baffles quickly when they arrive and notices the front pipes chrome plating is bubbling. I think it is just a visual problem. Does anyone know if there are any known problems with this issue? See pictures below
http://i489.photobucket.com/albums/r...9/134a22b0.jpg
http://i489.photobucket.com/albums/r...9/09a1d620.jpg
Old Mar 3, 2009 | 06:51 PM
phatman's Avatar
phatman
I think that's what the heat shields are for. I can't see it causing any "problem".
anubisss's Avatar
anubisss
This is under the heat shields is it not? I think you are fine unless it bothers you enough contact v and h.
Old Mar 3, 2009 | 07:05 PM
SC-Longhair's Avatar
SC-Longhair
I'm no tech but could that be a symptom of the engine running lean over a period of time? Wouldn't the engine run very hot and eventually may cause the bubbling the OP is experiencing?
Old Mar 3, 2009 | 07:11 PM
joejack's Avatar
joejack
Yes it is under the heat shield. I am assuming it is from the engine running lean. Hopefully the PC IV will solve that problem. The pipes have been on there for approximately one to two months.
swampfox_csa
Jul 10, 2012 01:28 PM
denimbob08
Apr 13, 2012 09:39 PM
MConde85
Feb 27, 2011 12:31 PM
DRenoK
Exhaust System Topics
May 10, 2007 04:48 PM
SPECIAL ED
Sep 15, 2006 03:18 PM
