M/C lift question
Old Mar 5, 2009 | 08:03 AM
SniperCJ's Avatar
SniperCJ
Default M/C lift question
OK, I *might* just be an idiot, but here goes...
I bought a lift the other day, was going to try it out and the crossbar on the front of the lift hits the kickstand so you cant put it under the bike. What am I missing??
Old Mar 5, 2009 | 08:10 AM
johnsa28's Avatar
johnsa28
There are adapters that you have to get to lift a dyna
Old Mar 5, 2009 | 08:11 AM
doxbike's Avatar
doxbike
Had the same issues myself. I bought a set of HD Dyna Frame Adapters for @$25.
do a search, many others have used 2 X 4's in a variety of configurations
Old Mar 5, 2009 | 08:16 AM
SniperCJ's Avatar
SniperCJ
Cool, thanks guys. Figured a couple of wood slats / 2x4's was probably the answer.
Old Mar 5, 2009 | 08:34 AM
FUQUA's Avatar
FUQUA
You better Strap That Mother Down!!!!!
Attached Thumbnails M/C lift question-bike3.jpg   M/C lift question-bike4.jpg
Old Mar 5, 2009 | 08:35 AM
dyna rider's Avatar
dyna rider
Default Lift
Could be you are trying to push it too far under. If you can see the lift arms on the L/H side without bending down, that's probably far enough. I always strap my bike to the lift before I jack it up.
Old Mar 5, 2009 | 08:46 AM
glide05's Avatar
glide05
You don't mention which model lift you bought .....
Sears yellow lift will ONLY work with the jiffy stand in the UP position, regardless of if you use the spacers or not.
Old Mar 5, 2009 | 09:39 AM
2007fxdc's Avatar
2007fxdc
If it's going far enough to hit the kickstand, it's going far enough to lift the bike unless it's some weird kind of lift. I have a buddy that notched his where the kickstand hits so he could get it further but I have the same exact lift as him and don't need a notch. Once I get the lift under the bike, I straddle the bike and stand it up straight and use my right foot to jack the lift up to a point where contact is made and a little weight is on the lift. Then I get off the bike and hold the handlebars with one hand for support while I finish jacking up the bike. Next step should be to lock the lift and strap the bike down. I do use the dyna frame lift adapters but others do use wood. However, the wood should be trimmed on the back right corner, just like the frame adapters are so that the bike sits level on the lift.
Old Mar 5, 2009 | 10:34 AM
ackman1968's Avatar
ackman1968
I pull the bike up on a 2X6 under both tires then grab the bars and upright the bike. Then I shove the jack in and everything clears with no problem. I use a harbor freight jack.
Old Mar 5, 2009 | 12:08 PM
SniperCJ's Avatar
SniperCJ
Jeeeezus! I never even thot of that. Always the simple solutions that get you. I have the same HF lift.
fastbydrmike
Mar 22, 2011 11:40 AM
lhcstreetbob
Jan 19, 2009 02:51 PM
PKellyMc
Nov 21, 2008 09:22 PM
PKellyMc
Nov 21, 2008 03:41 AM
MovedtoSyracuse
Dec 23, 2007 11:33 PM
