BCT Baffles
Old Mar 19, 2009 | 07:45 PM
  #31
Double00Aught's Avatar
Double00Aught
Originally Posted by MTBlood
I actually shot V&H an email tonight and asked if we need to modify the map with the BCT baffles.
I'll let ya'll know what they respond with....
I got my response from the FuelPak team, looks like no remapping is necessary.
Here is their reply...
With the new baffles you will still use FP-0535.
Old Mar 20, 2009 | 09:16 AM
  #32
r00k's Avatar
r00k
Do they seem to be running fine for you though?
Mine are running awesome with the fuelpak, but then again my machine wasn't running perfect before I installed them.
Old Mar 20, 2009 | 10:49 AM
  #33
IrishBrewed's Avatar
IrishBrewed
Originally Posted by Lorance66
it just does not have that raspy popcorn sound anymore. Much deeper tone, at idle its much more of a "blub blub" than a "pop pop"
are they easy install...how hard is it to switch with the V&H baffles?
Old Mar 20, 2009 | 10:52 AM
  #34
Lorance66's Avatar
Lorance66
for me on my BR it was really simple. Just remove the heat shields that are held on with hose clamps. Had to completely separate the front clamp in my application but not a problem. Then the VH baffles are held in with a button head bolt (allen key but don't remember size). Slide baffles out, slide BCT's in and they bolt in the same way with the same hole.
On my pipes, the upper baffle sticks and is hard to remove but there are threads on how to get that out if yours is similar.
Old Mar 20, 2009 | 10:56 AM
  #35
Hickey's Avatar
Hickey
ok, so you guys arent re-mapping the fuel pak for the 'quiet baffle' option?
Old Mar 20, 2009 | 10:58 AM
  #36
thomaskray's Avatar
thomaskray
It's amazing how simple they are too when you really look at them.
Old Mar 20, 2009 | 11:01 AM
  #37
Lorance66's Avatar
Lorance66
according to the paperwork there should be no re-mapping necessary. I am sure things are a bit different but not enough to cause a problem. My bike is running fine with no re-map so far. (not the QQ's)
Old Mar 20, 2009 | 11:42 AM
  #38
Hickey's Avatar
Hickey
ohhhh! boy do I feel like an idiot. I thought the original BCT's were quiet baffles, so they're just there to change the tone, sweet!
on that note,
anyone have BCT's in the VH short shots? which diameter should I order. Bike is at home so I cant measure it.
Old Mar 20, 2009 | 12:17 PM
  #39
ged533's Avatar
ged533
installed one bct baffle in a hybrid setup.2 into one header with a stainless tailpipe extension.great sound and performance.folks at bct were very helpfull with choosing the right length extension and placement of baffle.no regrets here.
Old Mar 20, 2009 | 12:57 PM
  #40
r00k's Avatar
r00k
on that note,
For my Short Shots I ordered the 2" Inside Diameter and the 2 1/8" Outside Diameter.
**The muffler measurements on the V&H site only list the Outside Diameter**
They do fit a little loose but Big City Thunder confirmed that is how they are supposed to fit.
There is also a Quiet Version of the BCTs that have a mesh cone on them.
EDIT: make sure the measure for your self too, just to be belt and suspenders about it.
